Finally, finish to put it togeter. block was sleeved and bore to 0.20 over.
new pistons and rings, polish crank, head redone,guides,seats valves seals, timing chain, gasket and seal all over. And its running perfect.
By the way , the crank sensor plug in is the same as the speed sensor don t mix them up, it will cause a no spark condition.Found out the hard way.
