If I knew where my camera was I would:P When it turns up ill take a pic of each type.
Billit Oil caps for LQ1
If the "oil" is aligned with the front of the motor, I would take one of those. If not, I'd take one of the same style without the oil engraved on it. Thanks.
325 whp 350 lb-ft
It can align no problem. If you tighten it all the way its a little crooked but its still tight with it lined up perfect.
It fit the 94-95 DOHC as well, unless this 95 engine I have is the 96 front cover. It also fit the Gen 3 pushrod valve cover so I think it may work for all 94+ setups. The half turn type that is.
Still haven't located my camera...Ben
