Baller Status 3500 Heads
  • Baller Status 3500 Heads
    What do you do if the best isn't good enough? You get them coated.
    What are they coated with?
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
      Swain Tech did the coatings, and they help block the thermal transfer from the combustion charge to the cylinder head. Keeping the exhaust hotter will help it travel faster out the exhaust.
        Interesting. It looks good!
          That is interesting and can you please explain the benefit of this or a link I can read up on the subject ? I read something lately about detonation elimination by coating the combustion chamber And keeping the thermal benefits. But they also talked about coating the ports also. With a dry film coating
            Didnt know they were in NY. Only a few hrs from me! ( assuming this is the same place... but then again ya know what happens when ya assume lol ) Looks pretty good and is something I might consider when I order some cyl heads!
            350/NV3500 5spd
              nice !!! this id the article i read http://www.techlinecoatings.com/arti...ad_Article.htm And was refered there when i contacted my local powdercoater for the lateral links i have coming .
                Ben, will this be a future option for cyl heads, or something we would have to send out?
                350/NV3500 5spd
                  I like that a lot.
                  Coupled with the same coating on my piston domes, this should help keep more heat in the combustion chamber and then flowing out the exhaust.
                  The theory is that less heat will be absorbed into the cylinder head, where it must be dissepated by the cooling system. So the motor may run a bit cooler, and it should help with durability of other parts.
                  And should also help to produce a smidge more power.
                  Matt
                    i had read up on this a long while ago in a import mag. seems they think its well worth it.
                    now all thats left is getting WOT-TECH CnC'd on the ends of the heads....good stuff!
                      Now that's an idea!
                      Ben? How's that for an idea to represent?
                      Matt
                        yeah sounds like a good idea and what was the total cost ? 230 ? 275 or both ?
                          $230 to coat the combustion chambers and valve faces, plus another $72 to coat the exhaust ports (6 @ $12 each), so $302 (plus shipping) total.
                          Matt
                            now if only someone had access to a small CNC, that had down time, they would probably do it for cheap, i dont think you would ever see the print due to brackets and such. would look really sexy when you pull them out of a box though. "woooo, WOT_TECH heads "
                              Well i have half baller heads then.lol
