Baller Status 3500 Heads
Interesting. It looks good!
That is interesting and can you please explain the benefit of this or a link I can read up on the subject ? I read something lately about detonation elimination by coating the combustion chamber And keeping the thermal benefits. But they also talked about coating the ports also. With a dry film coatingLast edited by unchained01; 01-13-2012, 11:11 PM.
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
nice !!! this id the article i read http://www.techlinecoatings.com/arti...ad_Article.htm And was refered there when i contacted my local powdercoater for the lateral links i have coming .
I like that a lot.
Coupled with the same coating on my piston domes, this should help keep more heat in the combustion chamber and then flowing out the exhaust.
The theory is that less heat will be absorbed into the cylinder head, where it must be dissepated by the cooling system. So the motor may run a bit cooler, and it should help with durability of other parts.
And should also help to produce a smidge more power.Matt
i had read up on this a long while ago in a import mag. seems they think its well worth it.
now all thats left is getting WOT-TECH CnC'd on the ends of the heads....good stuff!
Originally posted by bob442 View Postnow all thats left is getting WOT-TECH CnC'd on the ends of the heads....good stuff!
Ben? How's that for an idea to represent?Matt
Originally posted by unchained01 View Postyeah sounds like a good idea and what was the total cost ? 230 ? 275 or both ?Matt
now if only someone had access to a small CNC, that had down time, they would probably do it for cheap, i dont think you would ever see the print due to brackets and such. would look really sexy when you pull them out of a box though. "woooo, WOT_TECH heads "
