TCE adjustable fpr
  • TCE adjustable fpr
    I installed the afpr today literally in less than 5 minutes time. So what does this text on the wottech website mean?
    "TCE adjustable fuel pressure regulator. Comes fully assembled with a new regulator base (not used!)."
    I dont understand what is not being used. I popped the old one off in no time and hooked the new one up no problem. Did I miss something? cuz it works just fine. I hooked up a guage and adjusted it to 62 psi for 28lb injectors. Does it need disassembled and put back together using the stock base?
    You used to be able to buy just the top end of the regulator, and you'd have to assemble it yourself. Now, it comes pre-assembled. And the NOT USED part means that the bottom of the FPR is a new part that was disassembled and reassembled with the new top, not just a old (USED) FPR that was pulled off a car in a junkyard. So you are getting all new (not OLD, USED) parts.
      oh snappp
      I missunderstood that part lol
