could I get a price or option.....
I have a 1227730 ECU going into my '95 achieva. I got the ecu from a junk yard donor corsica circa '92, v-6. that's all i got for info on donor.
I would like a swap chip with the "3400 swap chip" burn on it with automatic and the moates version with the ZIF. I'm not really concerned with shift points, I plan on flashing them way off the board and doing all manual shifting, hence I'm swapping the valve body from a grand prix so I can get 1st gear at the shifter.
So do I buy the chip and send it to you from moates or can you get it and burn it, then send it to me?
side note, all track only. ecu has no control over fuel pump or fans, no emissions, heavy port and polish work, 75mm TB, 110 stat, 5k stall converter, no accessories ie no water pump, PS, a/c, cruise, abs, SRS, etc, all gone.
As you can see I missed a year of racing and have been a busy boy.
![smile](https://www.60degreev6.com/vb5/core/images/smilies/smile.png)
