I'm wondering if you guys were able to get a 3400 stroker kit out. I'm looking to bore 60 over and then up compression from 9.5:1 to 11.5-12:1, but can't find enough specs on the 3400 to figure out if 12:1 compression is even possible because of stroke limitations or clearance issues. 3500 heads and lim with ported/polished 3400 upper and bigger tb but just have questions on the more internal pieces like crank, cam, pistons, connecting rods and lifters.
3400 stroker kit?
Stroke and compression are 2 different things. I don't plan on selling a stroker kit unless we get custom cranks made with smaller rod journals and then rods to match. You can do 12:1 compression with 3.4 DOHC pistons in a 3400 block with 3500 heads. Its actually closer to 12.5:1. Forged pistons can be made for custom compression based on everything else, so as far as compression goes, anything is possible.Ben
