3900 phenolic spacer?
  • 3900 phenolic spacer?
    Any chance of getting some made for the 3900?
    what spacer? between the LIM and UIM or UIM and TB?
      between the upper and lower intake.
        Not really. Phenolic costs a lot and to do just a few would be very costly. I haven't offered any phenolic parts for years.
          ok, thanks for the reply.
            I think alot of ppl would be interested in these spacers again.. @ least the 3400 and 3500
            Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
              Less than you'd think. the idea is cool but in reality they don't make much difference at all.
              An aluminum version with nitrous nozzle holes would be sweet though.
                direct port without the work
                  I should do that with the ITB's.. muahahahahaha.......
                    Ive been looking for 3500 phenolic spacers for about a year with no luck
