Street/Strip Cam Idle
  • Street/Strip Cam Idle
    A couple of video's, hope you like them
    Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
    not bad it's got a nice steady idle.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
      Sounds good......very similar to mine (yours is just a bit louder).
      Had it tuned yet? I saw some pretty decent gains after tuning with similar mods.
      Matt
        Very nice Idle quality videos can really help people figure out which cam they want. That engine bay looks great too!
          I heard the same cam running on OBD1 in a 3400 with headers and it sounded quite a bit different... maybe the SFI is helping it out...
          Sounds good though, very smooth.
            Thanks for the comments
              what chain did you have prior? i would like to know if the 99 gm chain holds up with this cam...
                I was using the OEM, witch was very small. This chain streched in 5K, but this is do to the valve springs. I hear the pre 99 work great, but now I'm running the TCE timing kit with crank.
                  I have my 99 GM setup on there still and its holding up good. As noted though, its typically the springs that your using that will also speed up chain wear. I also had my chain cryogenically treated so that may be helping a bit. TCE is a nice solution, but I'm not up for tearing the whole motor apart again to have the crank turned.
                    Wow hearing jon's car and now your grand am. I want a cam really bad.I would really like to do a engine build in the very near future.
                      HAHA, one thing at a time now Rob... Lets get the stock pig running right, and then we can get you a mild street and strip cam to have some fun with.
                        here's mine for video sake. IIRC when Ben had the user videos on the WOT site he called it a stage 4 n/a
                        i've had the 99 GM timing set in there from the start and haven't taken it off or heard a peep from it yet. while mine may not have as many miles on it as Jon's it get's driven just as hard.
                        99 Grand Am GT
                          I agree 100% with you there i can't wait.I really can't wait to see what it can do!!!!
                            i could really use another video for a street/strip cam. or any other videos infact
                              Whatever exhaust you run has a lot to do with the tone of the cam.....you can barely detect mine.
                              http://www.streetfire.net/video/idle_2080284.htm
                              Matt
