"ATTN: If you are using 3500 heads on a 3400 block, you must use a gasket bore of 3.720" or larger to clear the combustion chamber."
I am using 3500 heads on a 3400 block and my question is what option do I select for the Bore & Thickness? I am just looking for the stock size; not looking to change compression or anything.
