Ben can you post the specs of the 1615 grind and the Stage 2 NA cams??
Cam specs 1615 & Stage 2 NA
206/206 260/260 .533/.533 lift 113 ICL 112 LSA is "stage 2" territory. I also have 2 other grinds with similar power output, 1 of which will work with yellow LS6 springs.
I don't know the 1615 specs, as they don't exist on WOT-Tech anymore. I use Comp Cams now, not regrinds.Ben
Originally posted by SappySE107 View Post206/206 260/260 .533/.533 lift 113 ICL 112 LSA is "stage 2" territory. I also have 2 other grinds with similar power output, 1 of which will work with yellow LS6 springs.
You don't have access to the list you used to have with all the specs in the store in the store??
I need to sell my 1615 and I have to post up the specs.
I have 1 print out before I deleted everything and it wasn't in front of me out in the garage.
280.6/283.8 duration seat to seat 225/227.6 duration .050" .603/.562" lift 111 ICL 111 LSA
I didn't assume you were selling 1 cam when you asked for the stage 2 cams along with it.Ben
I have the entire list saved somewhere...
Ben, is the cam you sold Damon a regrind or a new Comp one?
Originally posted by SappySE107 View PostI have 1 print out before I deleted everything
I'm pretty sure he has it in at least 1 backup, since he made a complete backup of the store prior to our server move.-Brad-
Sorry for the late reply, however does this help at all?
