I have just changed throttle body from the 52mm to a 56mm. When i got back on and started 3 times now the car has a lopey idle. Once alittle warm it stops but rpms are about 100-150 higher. Does anyone have a suggestion to problem or could it be something i miss installed.
96 lumina rough idle at start
I replaced the IAC and got a new gasket and found a vacuum line that goes from PCV to throttle and behind motor loose. I reattached line and Rpm went back to normal. When the motor is started cold it kind of acts like its not getting enough air. If i touch throttle alittle and get rpms to 1000 to get it alittle warm its ok then. I'm beginning to think i just need to adjust the throttle screw on TB. What do you suggest? The Throttle position sensor has not been replaced. Should i replace also? Other than that the car runs more responsive and feel a power gain and using less gas.
The screw on the throttle body is just a stop screw and should not be adjusted. If the ECM learned the IAC position from having the vacuum leak, it may take some time for it to learn that it needs more IAC steps than before. I would run it for a while and see how it works out.Ben
Originally posted by SappySE107 View PostThe screw on the throttle body is just a stop screw and should not be adjusted. If the ECM learned the IAC position from having the vacuum leak, it may take some time for it to learn that it needs more IAC steps than before. I would run it for a while and see how it works out.
That ring was just in place for the shaft and doesn't go back on when you swap shafts. I deal with that on the billet throttle bodies so I know it isn't necessary.
I don't know how long the OBD2 computer keeps its memory. OBD1 is basically instant once it loses power.Ben
