Underdrive pulley with damper for 3400
  • Originally posted by 3400-95-Modified View Post
    So complete honesty here... Did I give away my FFP UDP for free for nothing?
    It sounds like this project is DEAD... I would at least like my pulley back so I can sell it elsewhere, OR I would like some money for it.
    I did not expect to never see it or progress on this again.
    Can we still get an update on the underdrive damper pulley please?
    • Re: Underdrive pulley with damper for 3400
      Last I heard, they were having issues with the 24x ring, just like all the other companies...
      Sent from my Devour using Tapatalk
      • Guess John didn't want to reply after all. He got the pulley back so its not gone forever. However, I have no news on a pulley being made and consider this dead.
        • Speaking from a manufacturers point of view, with the limited 60V6 marketplace, it is hard to justify the investment in design, tooling and inventory of a new product. When you add in the economy being slow and people spending less on their toys, new products will be far between.
          MinusOne - 3100 - 4T60E
          '79 MGB - LZ9 - T5
          http://www.tcemotorsports.com
          • so far an aluminum pully with the wear issue:
            when i did a timing chain on a 2.2, i got a steel sleeve and larger seal, so i would assume the same could be purchased for the 3400, if its not already the same as the 2.2 anyways.
            • The aluminum pulley's that did exist, had a steel sleeve pressed over the shaft already, and the seal was the same size as stock since the stock pulley is steel to begin with.
