after looking at the pump closer, it appears its just the body thats going to be clearanced and it SHOULDNT hurt the pump. the only problem is that where i would be grinding is very close to where the drive shaft attaches and i dont want to hurt the strength of the pump. but ill try grinding the pump tomorrow. edit: is there supposed to be a gasket between the pump and cap? i dont remember taking one off but id rather be safe than sry. thx
main stud kit problems
[SIGPIC]
12.268@117... 11's to come!
Originally posted by ForcedFirebird View PostThe whole stud was turning becasue you didn't use the allen key to snug the stud in the bottom of the blind hole in the block.[SIGPIC]
your studs look shorter than the studs i was given. look at my first 2 pictures. front with no washer, and front of yours with no washer. your studs must be different than mine.[SIGPIC]
I had the same issue with oil pump clearance. I shaved off about a 1/16 of an inch off the pump which provided just enough room for the stud, nut, and double stacked washers. Just to clarify though I am working with the lz9 motor.98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
right, same problem. but i have 327 rods, the crank scraper i bought from the site, isnt as thick as u seem. its just been a huge hassle. i have pix of the main stud cut down, an i grinded a notch for a flat head screwdriver... just been too busy to take pictures.[SIGPIC]
sorry about the delay, but i have had NO time this week to go over to my garage and snap some pictures. ill be there friday for sure to get this engine in.[SIGPIC]
