quick question regarding 60degree store chip
  • quick question regarding 60degree store chip
    I have a 93 cutlass vert with the LQ1, Im curious to find out if you have to physically block off the EGR to get the delete option with your chip or does just getting the off option with the chip do the trick? If I have to block it off where do I get a block off plate from?
    thanks
    1993 Oldsmobile Cutlass Supreme Convertible...K&N Intake, 180 T-stat, magnaflow high flow cat, dynomax mufflers, WOT Chip, 18in black focal rims w/ bridgestone potenza's
    2003 Chevy S-10 LS Crew Cab 4x4
    4.3L V6
    As long as your EGR is not stuck open, you don't need a block off plate. The code will keep the EGR closed.
