Bronze gear for billet cams
  • Bronze gear for billet cams
    I am selling these as just the gear or complete and ready to install. If you are using a cammotion cam, you should be running this gear (they recommend a bronze or polymer gear with their cams).
    Here is a comparison picture of the bronze gear and a stock 3500 drive gear.
    whats the price?? looks bad ass
      90 bare, 120 ready to install. I have 1 of each in stock right now.
        hey Ben do you happen to have the p/n for the brown high temp oring for the dist drive?
          No I do not. If you get it please let me know.
            ok ill see if i can find it tomorrow, so can they be had from any non vvt 3500 right, like an 05 G6?
              The brown oil pump drive ring? Its for 2.8-3.5 60V6s. I found the dorman number for the black o ring. # 90441 At least, its black in the rockauto pic.
                so its anything for the 2.8-3.5, but the brown is the high temp rin???
                and the high temp ring comes standard on the 3500s right, and we are talking about the same thing, u didnt think i meant the bronze drive gear did u?
                  The oil pump drive O ring. yes, the 3500 got it stock so you can just ask for that. I know the dealership here understands what I want if I tell them I need the oil pump drive O ring for a 3400 grand am, and I want the high temp version.
                    well yah the dealership here will know that also, and is there any other part # uneed from that setup?
                      Nope, just the brown O ring.
                        ko, consider it done
                          ok p/n looks to be 1977937 but i ordered one to make sure that was it, it should be here in a few days, then ill make sure its what the pn says, the reason i am sceptical about the pn, it said washer for the desc. so i wanted to make sure, ill let you know when i get it in
                            should be getting it in weds, had to come from Michigan, and they come in a pack of 10
                              Have you recieved this yet to verify the PN?
