3.1L/3400 hybrid swap.
  • nothing too special on the firing order and very easy to remember... It's just the coil arrangement that's a pain to remember.
    • If you go left to right on the coils it actually comes out to be 1 2 3 4 5 6 (looping once). That's how I remember it
      '86 Fiero, 3500, 4-speed
      • Update on the build. Tuned it all day. Got it somewhat dialed in. Running med boost. Heres a vid. Plan to make a pass at the track tommorow if all goes well. Not trying to kill it, just make a clean pass or 2 and see what it can do with about 10psi.
        1/4 mile best 11.59@119mph
        1/8 mile best 7.47@94.9Mph
        • HIt the track today!
          I added 2 videos and a few slips for ya to check out. Totally fell asleep on the 2nd round and had such a horrid light. Been a long few days...to get the car tuned and ready but it ran great. Drove a 120 mile round trip also and it did well.
          I love not having a screamer pipe now. All i can hear down the track is the turbo and some throtty exhaust. Love it.
          Did i mention that this car is surprisingly consistent! Love that alot.
          First time at the track with hybrid - YouTube
          First time out. 1st round on brakes for the win - YouTube
          • Nice! Good runs for the first time out! How much boost?
            14.96@91.47 in the 1/4
            9.63@74.36 in the 1/8th
            • My Trooper needs boost.
              • Happy with the times so far? How does it compare to last years setup?
                • Running abour 12.5-13Psi of boost. And the tune is very conservitive, the timing is 2 degrees lower then last year at that level. 17.5*ish at 13psi.
                  Im very happy with the times so far. Considering I was launching at arround 1700rpms and I have a 3000 stall on it, the 60 ft times could be alot better and drop the ets in time. Last year I could hold and launch at arround 2600rpm and catch 1.7x 60 foot times. Yesterday i was knocking down 1.9x 60 ft times.
                  Last year it felt very slow at the top end of the track. This year it really drags you down. I gained about 7mph on my trap speed. Last year I was averaging 103-104mph. So im loving the hybrid set up alot. Much better flow at high rpms.
                  • Did you port the top end at all before installing?
                    • The heads a bit. Worked the valve bowls slightly and knocked off the cast lines. Not a lot though to be honest. I didn't touch the intakes at all.
                      • i had tried 123456 but the car wont start rather rough idle and stop and the coil pack numbering, facing the hood from right 6/3 2/5 1/4
                        • Follow the coil pack numbering. If it's still misfiring there's another problem
                          • my RPM clock stopped moving i wouldnt no where the fault will be from pls tell me where to follow it from
                            thanks
                            • ok i tried setting the wires like 165432 and the car started
                              • Are the coil packs installed out of order? Can you post a picture?
                                Sent from my XT1058 using Tapatalk
