03 GAGT LX9 and Getrag F-23 swap!
Holy cat eater!
Originally posted by _HeC_ View Postlol ya decent size but nothing special sadly, just a godspeed GT35... I've seen too many LS china turbo builds with good success and a buddy had this turbo kicking around brand new for a decent price so see what happens I suppose"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
little paint/polish
found out the hard way you need to buy disc brake hardware for BOTH C5 and the F-body to make these work lol but got the fronts on for now
didn't think the C5s cleared 16s with the ribs on the top but I had to try and sure enough they do
also got my front lip on a week or so ago as well
picked up a Zex wet kit off my buddies twin turbo vettehe only filled the bottle twice so barely used
anyone have thoughts for switch placement? Dash seems to round to mount a switch anywhere without looking goofy, might make a temp panel to fill the void under the radio but I was planning on upgrading to a double din soon...
for nozzle placement I'm debating on drilling my TB adapter or it came with the fitting to bolt onto my intake
Originally posted by Maple Leaf View PostVery nice! Must be a big improvement on braking. Any plans for a rear brake upgrade? Pontiac Grand Prix GXP brakes would compliment the front brakes.
Will be buying another turbo as well and selling my godspeed gt35 or maybe keep it as a back up... 7L CAT Borg Warner turbo will be going inBorg Warner SW300
will need some cutting and welding I'm sure but this is the budget setup I'm going with! Dual LX9 front manifolds and a custom crossover
got a double din for cheap so tossed that in as well after a little cutting
finally got my dual posts painted and installed
started a new stereo setup for the trunk
few more layers and quick trim is as far as I got for now, to busy and more important things then a fancy sub install lol
got my nitrous mocked up and bracket welded up for the Zex control box, final install this Sunday I think
welded the bolts on from the back side to make install easy
7-8hrs on the road to meet up with a fellow N-body owner to get my "mint" carbon fiber SCT hood, I returned home still hoodless as the "mint" hood had 3 out of 4 stripped mounting points and a rather big bubble in the middle of the hood that was lifting
also found a better sounding video from my dyno run online from someone that was at the shop the same day
I was only going to shave off the casting lines but couldn't stop once I got started lol J-body poly bushings as well
10yrs since I've been in front of these lights, felt SOOO good!
That little F23 has also taken a good beating this season with daily driving it and 30+ passes in one nightlol
Now I really don't trust my dyno, "165whp"sure does move pretty quick in a 3200lb car lol Could not launch this thing tonight(was really cold) but was hitting 99.7mph traps... has a better time in it I think
Bunch of 99.X mph runs and then this! 200+ to the wheels easily
Dropped my exhaust lastnight and got a o2 bung welded in for my wideband
B&M short shifter which I'm hoping to get in by Mondays track day
and guess that LX9 is getting cracked open over winter
think that catches things up... winter build to follow
Working 6days a week 8-12hrs a day and with other shit always popping up getting in my way I didn't start tearing the car apart till Jan 2016
Tossed my exhaust manifolds on as well as the crossover fabbed for a 2nd gen J-body with flipped UIM.... I didn't think it would work but tried it out anyways lol
so grabbed a new turbo flange and pretty much started over trying to hug the engine as close as I could to make way for a 3" downpipe
The red transmission cap should give you a good reference point for how much it moved
How thing's are sitting right now, just need to finalize turbo location and make some brackets to hold it then I'll finish the last couple bends
