Ok this may sound like a dumb question, but here goes. I bolted up the engine stand plate to my 3500 engine today and used M12 grade 8 bolts which seemed to fit ok, but I just want to make sure that is the correct size bolt before I set the engine in the stand under it's full weight. Can anyone confirm the correct engine block bolt size for a 3500?
This is my first experience using an engine stand and I want to make sure I do it right so this puppy doesn't end up on the floor due to a dumb mistake. Thanks....!
[IMG][/IMG]
[IMG][/IMG]
