thanks for the advice guys, I will certainly use it!
Plans for L32/3X00 Hybrid
93 Firebird 3.4
Slowing down will always provide for more rational thinking and not screwing anything up. And as you stated, you have plenty of time, so no need to solve every problem right away.
As far as the tap goes, be careful not to go too far with it. The first time I tapped the LIM, I went too far, and the tap ended up inside of the thermostat cavity. I couldn't rethread it out, and there was no way to rotate it inside the cavity, so I ended up having to destroy the brand new threads (and the LIM in the process) to get the tap out. Just a word of caution...-Brad-
Originally posted by bszopi View PostSlowing down will always provide for more rational thinking and not screwing anything up. And as you stated, you have plenty of time, so no need to solve every problem right away.
any ideas on what I could practice on first? Seems like it would be a worthwhile investment of time to do a few trial runs and get the hang of it.
93 Firebird 3.4
Take your tap and oil to the junkyard and have funsigpic"It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
Originally posted by 80Scooter3.4 View PostTake your tap and oil to the junkyard and have fun
Or you could use a toothpick or something as a depth gauge and put some tape on the tap just a bit closer to the tip of the tap as your marker, so you don't bottom it out.-60v6's 2nd Jon M.
so how far in do i really need to go? The plan right now is to tap into the unused coolant passage in the LIM using a 1/2" NPT tap and then I guess threading in some kind of 1/2" -3/8" reducer which will allow me to install a gm 3/8 CTS
93 Firebird 3.4
Wow, now you see how worn out I am. I was thinking you were tapping a bolt hole, not the CTS hole.I would only run the tap like maybe 1/4 in farther than the thickness of the metal there, that way you get threads all the way down. You also wouldn't bury it in there going that far either.
so only a 1/4 of an inch into the hole?
93 Firebird 3.4
1/4" deeper than the hole goes. Reason being, the end of the tap is tapered, so you won't get good threads all the way down if say the hole was 1/2" deep that you needed to tap and you only ran the tap down 1/2". That's why I would do the extra 1/4", to get the tapered portion of the tap through to thread the hole the entire length.-60v6's 2nd Jon M.
I found a site where I can order some nice "allen head" bolts for my 3400 TB and UIM. The "kit" comes with the bolts for other things as well but I really only need them for the UIM and TB. Since I can't seem to find a set of factory UIM bolts anywhere it looks like I'll be picking this set up. I suppose these bolts will look a bit nicer than stock anyhow.
93 Firebird 3.4
NEW PARTS!!!
3500 LIM & Rocker arms:
that's all for now!
93 Firebird 3.4
You must not have a Mrs. Mine would have my hind end for having engine parts on the kitchen table, lol. That and ours is 1/4" glass w/ a tapered and rounded edge...-60v6's 2nd Jon M.
Be sure to keep the centerline of the tap inline with the center of the hole. A 12 point socket will fit on the square shank of the tap and makes it much easier to keep the tap lined up. Correct thread depth can be easily maintained without a thread gage or mating part. Simply run the tap in until there are seven threads left exposed. This will work for all sizes of pipe taps.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
Originally posted by pocket-rocket View PostYou must not have a Mrs. Mine would have my hind end for having engine parts on the kitchen table, lol. That and ours is 1/4" glass w/ a tapered and rounded edge...
And that's not the kitchen table, it's a coffee table
as if that were better haha
93 Firebird 3.4
Originally posted by CNCguy View PostBe sure to keep the centerline of the tap inline with the center of the hole. A 12 point socket will fit on the square shank of the tap and makes it much easier to keep the tap lined up. Correct thread depth can be easily maintained without a thread gage or mating part. Simply run the tap in until there are seven threads left exposed. This will work for all sizes of pipe taps.
93 Firebird 3.4
