I successfully completed a "3.1 I/C Turbo" topend swap onto a 3400SFI with a T3 upgrade a couple years ago. It was realtively easy and became a real monster on the street with only 10psi boost. I am thinking of doing the same thing with a 3900 shortblock. Will this be possible with the 3900? I read somewhere about offset bore centers and some other things. Anyone know or point me to a detailed info on the 3900. Thanks.
3900 top-swap (3.1 Turbo)
Originally posted by robertisaar View Postso you stuck Gen2 intakes and heads on a 3400 block?
Now I want to do the same thing, 3.1 Turbo heads and intake ("3.1 Intercooled Turbo") on a 3500 or 3900, whichever will work, the bigger, the better. But I fear issues with the 3900.
It is for my 1990 6000 S/E AWD. Pontiac built two 3.1T AWD cars for testing. I want this to look bone-stock from the outside, as if installed by Pontiac. But I want the biggest bang for the buck. Can you blame me for that?Jeff Ianitello
Engineered Performance
Atlanta, GA.
A Gen 2 top end isn't as bad as some people make it out to be. The main restriction is the intake, and a turbo helps defeat that problem. Granted the exhaust manifolds could be used on the Gen 3 top end with minor modification.
Before I started reading this forum I had purchased a set of rebuilt Gen 2 heads and gasket matched the top end. I'm not sure if it is worth rebuilding the old Gen 2 bottom end when I can pick up something Gen 3 with less miles and no bottom end work needed for fairly cheap. Get some new piping and a bigger turbo and it should move pretty good for a junkyard motor. When it dies I can take all the turbo specific parts off and move to a complete large port motor.
That being said I'm fairly certain it would not fit on a VVT 3500/3900 block. It probably could work on a 3500 LX9 and make more power than stock but would be rather choked compared to the 3500 top end. The TGP exhaust manifold ports could be made into a D shape to fit the 3500 heads.
that "bone-stock look" is killing power... biggest bang for the buck would be to use a full 3500 motor and just stick a turbo right to it and a TCE Crank Trigger and you're pretty much done, aside from exhaust/intake plumbing.
and from what i read here, only the VVT 3500/3900 have the issue of the bore offset, so a non-VVT 3500 could work... after all, people do stick non-VVT 3500 heads on a 3400.
3900 won't work for this. It's considered gen4.
LX9 3500 (gen3.5) might work, not sure about the heads etc from a gen2 though working on it. And for sure putting gen2 heads on a 3500 is a huge reduction in power.sigpicNew 2010 project (click image)
So a 3500 (non-VVT) will work? I already have a 3400, so I might just go ahead with that. Restriction on the intake side will not be an issue. I will be using a T3/T4 hybrid turbo. I understand the "loss" of power, but the "stock appearing" is alot more important to me. If I have to turn up one more pound of boost to make up for the possible loss of power (as opposed to just building a stock 3500 with turbo), then so be it.
I'll be looking for about 350FWHP. The limit will be the power has to go thru a TH125 transmission into the AWD transfer case. That, I am not worried about, nor am I concerned about the rear differential in this car. It is a front diff from an S10/T10/Astro AWD that was turned backwards. It is a 7.25" R&P. More than adequate. I'll be building some custom parts fo the TH125 to keep the 2nd band alive and well.Jeff Ianitello
Atlanta, GA.
3.1 heads on a 3500 would yield about 10.7:1 compression.
Originally posted by pontiacjeff View PostI measured the chambers on the 3400, but I don;t rememebr what it came to, do you recall the difference int he 3.1 and 3400 chamber size?
that explains why the 3.1T topend ran so good, the slightly smaller chamber gave a slight boost in compression, not to mention the base compression was higher, too. The 3.1T is (IIRC) 8.0:1. The 3400 engine is ~9.25:1, so I bet my hybrid was about 9.5:1.
I have decided to simply build another version of that hybrid for my 6000 AWD. It will be a simple swap with only a/c lines needed customizing. I will run it on a 3.1T computer with the 8F definition that I have tuned many times. I am looking forward with great excitement. I'll start a new thread soon so anyone interested can follow along.Jeff Ianitello
Atlanta, GA.
