I got a 98 GA with the 3100 v6 and i have been looking around several sites like Wot tech reading about the swap, all i want to do is the lower and upper intake from the large port 3400 or the 2000 + 3100 plenum. Could i use a gasket kit designed for the newer 3100(lg
or 3400 , or will i need to buy some sort of hybrid gasket set like the one Wot-Tech sells that they say is made to fit the 3100 head cuz they have some sort of pin to align the gasket that its not in the newer lim. About the heater core tube, i saw a thread were someone mentioned that the lim off a 96-98 3400 that is used in minivans will have the threaded insert so my stock 3100 tube will fit, instead of getting the whole tube replaced with the press in one.
Is there anything else about this swap that i have to worry about, i already know i gotta remove the pushrods to be able to put the new gasket in but that i will do with those rocker arm compress tools that are around.
