I have a '99 Pontiac Montana with the 3400 in it. It recently threw a rod and I need to get this engine replaced. I have been offered a free running 3100 that supposedly came from a '95 Olds Cutlass Ciera. Is it possible to either swap the 3400 for the 3100 or make a hybrid from the 3100 bottom end and 3400 top end. With the hybrid idea, I'm not even sure if it would be necessary to make it that complicated if a simple engine swap would work. What other issues should I be looking at? Will the 'puter from the Olds be necessary to run the 3100, or will the 3400 'puter run the 3100? I need to let this guy know asap whether or not I will need this engine before he simply scraps it.
Thanks all!
Thanks all!
