4T4x-E Mechanical Specifications Information
  • 4T4x-E Mechanical Specifications Information
    4T40-E/4T45-E Automatic Transaxle Unit Repair
    NOTE: Click on images to see a full-size view.
    Fastener Tightening Specifications
Name:	Fastener Tightening Specifications 1.gif
ID:	424751 Click image for larger version
Name:	Fastener Tightening Specifications 2.gif
    End Play Specifications
Name:	End Play Specifications.gif
    Reverse Clutch Backing Plate Specifications
Name:	Reverse Clutch Backing Plate Specifications.gif
    On-Vehicle
Name:	Fastener Tightening Specifications 3.gif
    General Specifications
Name:	General Specifications 1.gif
ID:	424753 Click image for larger version
Name:	General Specifications 2.gif
    Range Reference
Name:	Range Reference.gif
    Shift Solenoid Valve State and Gear Ratio
Name:	Shift Solenoid Valve State and Gear Ratio.gif
    Shift Speed
Name:	Shift Speed.gif
    Flex Plate A/T
    • Flywheel to Torque Converter - 46 ft.lb.
    • Engine Flywheel Bolt - 52 ft.lb.
    Fluid Pan A/T
    • Oil Pan to Case - 124 in.lb.
    • Bottom Pan to Case [M6x1.0x19.0 (Qty.12)] - 106 in.lb.
    Capacity Specs
    • Pan Removal and Replacement - 6.9qt (US)
    • Overhaul - 9.5qt (US)
    • Dry - 12.9qt (US)
    Note: Recheck fluid level after filling system
    • geldartb
      geldartb commented
      Editing a comment
      that's good i was just thinking of the people that don't have high screen resolution.
    • mfuller
      mfuller commented
      Editing a comment
      Please note that the table of available ratios has a typo - a 35/35 chain with a 3.05 Final Drive equals a 3.05 Effective (Overall), not 3.42. It's a GM typo that even shows up in my service manual.
    • hankjr40
      hankjr40 commented
      Editing a comment
      Does anyone have a diagram of where the checkballs go in a 4T60E ? I have a 1995 Buick Riviera and Im replacing the valve body with a updated one and have never been inside a transmission before and I hear these check balls can fall out easily
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
  • 4 Speed Automatic Transaxle Info
    by robertisaar
    The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
    10-08-2010, 02:48 PM
  • 4T65E and 4T65E HD (99+) N-Body Swap
    by onefastV6
    So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
    09-20-2010, 09:36 PM
    by bszopi
    On-Vehicle
    Range Reference
    Shift Solenoid Va...
    08-18-2010, 09:25 PM
  • 4T65E Hardened 4th hub and solenoid upgrade
    by Tbay99Venture
    INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
    07-24-2010, 10:59 PM
