4T65E Hardened 4th hub & solenoid upgrade
  • Opening The Transmission
  • 4T65E Hardened 4th hub and solenoid upgrade
    OPENING THE TRANSMISSION
    This is what it's all about. Don't strip the Torx bolts!
    The lower T-40 bolts are known to be trouble to remove. Thoroughly clean the bolt heads and crevices so the bit can seat fully.
    Tapping the bolt head with a chisel around the edges may help beak them free.
    An old-style hammer powered impact driver attached to the Torx bit is helpful.
    Once the Torx bolts are out, loosen the other bolts several turns but leave in place.
    With MUCH care the cover gasket can be reused.
    First, confirm the case is free but retained by the loosened bolts.
    Remove most of the bolts and carefully back out the others enough to allow play between the case & cover to confirm the gasket is free from the case and cover. The gasket has 3 strip sections and should be supported with 2 hands so it doesn't tear at any junction once free of the transmission.
    As carefully as possible remove the gasket and cover through the wheel opening.
    You now have access to the wiring harness inside the transmission. Carefully use a screwdriver to raise the tabs enough to unplug the harness connectors. Do not flex the tabs excessively as sometimes the plastic has become brittle.
    Most solenoids can be removed by pulling the steel clip from the exposed valve body channel EXCEPT the one for the TCC/PWM solenoid, you must remove the oil pump first for that solenoid.
    • Kristopher Gerbracht
      Kristopher Gerbracht commented
      Editing a comment
      I own an 85 6000 STE with the 'W' engine and TH 125 C. I did not see any specific date for the 'W' engine or the TH 125 C. Will I find any information somewhere else?
    Posting comments is disabled.
Article Tags
There are no tags yet.
Latest Articles
  • 4 Speed Automatic Transaxle Info
    by robertisaar
    The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
    10-08-2010, 02:48 PM
  • 4T65E and 4T65E HD (99+) N-Body Swap
    by onefastV6
    So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
    09-20-2010, 09:36 PM
  • 4T4x-E Mechanical Specifications Information
    by bszopi
    4T40-E/4T45-E Automatic Transaxle Unit Repair
    NOTE: Click on images to see a full-size view.
    Fastener Tightening Specifications
    End Play Specifications
    Reverse Clutch Backing Plate Specifications
    On-Vehicle
    General Specifications
    Range Reference
    Shift Solenoid Va...
    08-18-2010, 09:25 PM
    by Tbay99Venture
    INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
    07-24-2010, 10:59 PM
