Throttle Body Spacer
  • Throttle Body Spacer
    Port injection
    The TB spacer is meant to keep the throttle body cooler, by separating it from the manifold using a phenolic material instead of metal. The misconception is that by adding space behind the TB, you are going to get more torque.
    The lowered temperature is fine, and is worthwhile (see TB coolant bypass), but the cost of a spacer and the remaining intake manifold temperature doesn't do a whole lot on its own. The performance myth with this device is that it allows more air in, or that it lengthens the runners, or anything else along these lines.
    The torque curve is dependent on a lot of things, but for the TB related part, its actually not even related. The plenum, while connected to the runners, aren't part of the runner equation. You would have to lengthen the runners themselves to do anything. Actually, even this doesn't seem to work from testing on a 3100 with 1" spacers between the lower and upper intake. You would likely have to change the volume of the runners much more than just extending them will do.
    Regardless, this has nothing to do with the plenum. The plenum volume is important to performance and the RPM range of the powerband, but the TB spacer isn't going to have any effect on this because its volume is minimal.
    The only real value to a Throttle Body spacer is for a NOS setup. You can drill a hold in the spacer for a NOS injector. It is easier to work with a separate piece for the nitrous injector, and it is easier to return the car to normal later.
    TBI, Carb
    Unlike the port injected manifolds, a spacer that goes under the carb or throttle body will help out for performance. The extra space will help the air fuel mixture atomize, which will burn more efficiently. The myth part is for the port injected motors only.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
      by bszopi
      Port injection The TB spacer is meant to keep the throttle body cooler, by separating it from the manifold using a phenolic material instead of metal. The misconception is that by adding space behind the TB, you are going to get more torque. The lowered temperature is fine, and is worthwhile (see TB coolant bypass), but the cost of a spacer and the remaining intake manifold temperature doesn't do a whole lot on its own. The performance myth with this device is that it allows more air in...
      05-31-2010, 05:32 PM
    • Throttle Body Heat Shield
      by bszopi
      Its 2024 and this needs a bit of an update. We have been using 3D printed materials and had to use a throttle body heat shield to keep the header from melting our part. This was PETG, so definitely not the best for this application, but the shield worked. It was made of steel and bolted to the bottom 2 bolts of the throttle body. Also in a race car, which is a different scenario than the original article was written for. We originally wrote that a metal heat shield is going to become a heat...
      05-31-2010, 05:31 PM
    • Throttle Body Coolant Bypass
      by bszopi
      This isn't so much a myth, as it is exaggerated. The lines were put in by GM for cold climate conditions, which is said to cause ice to form on TB, which could cause a lot of problems, like a stuck open condition that can cause an accident. There have been no known reports of this happening, but there hasn't been any research either. ...
      05-31-2010, 05:30 PM
    • Electric Superchargers
      by bszopi
      There are several different versions of this myth floating around.
      Here is one view on why electricity and boost don't mix: Click Here!
      05-31-2010, 05:28 PM
    • Thermostat
      by bszopi
      I'm going to keep this short, because its a simple concept. For years people have been spreading the word that a 160 stat will cause problems. This is true, as it hurts gas milage and MAY cause the cylinder walls to wear faster due to less expansion. If your fan turn on times aren't matched, it can allow a cycle of 160 to 220 degrees back and forth, which will contract and expand the cylinders. ...
      05-31-2010, 05:26 PM
    • IAT Resistor Mod
      by bszopi
      IAT stands for Intake Air Temperature. It is a simple thermistor that changes its resistance according to the temperature it is at. The idea beind this modification, is that by changing the resistance to that of a cooler interpreted reading, you will get more fuel. While it is true that you will dump more fuel...its false that this is a good idea. Running rich is bad for performance, so you are just wasting your time with adding more fuel in this fashion. ...
      05-31-2010, 05:07 PM
