Throttle Body Coolant Bypass
  • Throttle Body Coolant Bypass
    This isn't so much a myth, as it is exaggerated. The lines were put in by GM for cold climate conditions, which is said to cause ice to form on TB, which could cause a lot of problems, like a stuck open condition that can cause an accident. There have been no known reports of this happening, but there hasn't been any research either.
    The idea behind removing it has nothing to do with the ice though, it is removed to keep the hotter coolant from heating up the TB. Cold air is good for a motor's performance, but the air moves so fast that the TB temp isn't really going to make a difference. Cooling the TB and Intake manifolds will help however.
    The real gain from this mod is to eliminate one area that "can" leak, and if you tear the motor apart at all, those coolant lines can be a pain to remove when you want to remove the TB or the plenum. Because this is a really cheap modification, it is still recommended to remove the lines if you don't have to worry about ice forming on the intake (only because it would be bad to recommend something that could be potentially dangerous). Every little bit helps when cooling the intake, just don't think you will notice anything from it. Not only will you not notice anything, you won't get anything on a dyno because of it either (on its own).
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Throttle Body Spacer
      by bszopi
      Port injection The TB spacer is meant to keep the throttle body cooler, by separating it from the manifold using a phenolic material instead of metal. The misconception is that by adding space behind the TB, you are going to get more torque. The lowered temperature is fine, and is worthwhile (see TB coolant bypass), but the cost of a spacer and the remaining intake manifold temperature doesn't do a whole lot on its own. The performance myth with this device is that it allows more air in...
      05-31-2010, 05:32 PM
    • Throttle Body Heat Shield
      by bszopi
      Its 2024 and this needs a bit of an update. We have been using 3D printed materials and had to use a throttle body heat shield to keep the header from melting our part. This was PETG, so definitely not the best for this application, but the shield worked. It was made of steel and bolted to the bottom 2 bolts of the throttle body. Also in a race car, which is a different scenario than the original article was written for. We originally wrote that a metal heat shield is going to become a heat...
      05-31-2010, 05:31 PM
      by bszopi
      This isn't so much a myth, as it is exaggerated. The lines were put in by GM for cold climate conditions, which is said to cause ice to form on TB, which could cause a lot of problems, like a stuck open condition that can cause an accident. There have been no known reports of this happening, but there hasn't been any research either. ...
      05-31-2010, 05:30 PM
    • Electric Superchargers
      by bszopi
      There are several different versions of this myth floating around.
      Here is one view on why electricity and boost don't mix: Click Here!
      05-31-2010, 05:28 PM
    • Thermostat
      by bszopi
      I'm going to keep this short, because its a simple concept. For years people have been spreading the word that a 160 stat will cause problems. This is true, as it hurts gas milage and MAY cause the cylinder walls to wear faster due to less expansion. If your fan turn on times aren't matched, it can allow a cycle of 160 to 220 degrees back and forth, which will contract and expand the cylinders. ...
      05-31-2010, 05:26 PM
    • IAT Resistor Mod
      by bszopi
      IAT stands for Intake Air Temperature. It is a simple thermistor that changes its resistance according to the temperature it is at. The idea beind this modification, is that by changing the resistance to that of a cooler interpreted reading, you will get more fuel. While it is true that you will dump more fuel...its false that this is a good idea. Running rich is bad for performance, so you are just wasting your time with adding more fuel in this fashion. ...
      05-31-2010, 05:07 PM
