3100 (Gen 3) Specifications : L82
  • 3100 (Gen 3) Specifications : L82
    Application
    Specification
    Metric
    English
    General Data
    Engine Type
    60° V-6
    Displacement
    3.1L
    191 cu in
    RPO (VIN Code)
    L82 (M)
    Bore
    89*mm
    3.50*in
    Stroke
    84*mm
    3.31*in
    Deck Height
    224 mm
    8.818 in
    Compression Ratio
    9.5:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    103 kPa
    15 psi @ 1100 RPM
    Cylinder Bore
    Diameter
    89.016-89.034*mm
    3.5046-3.5053*in
    Out Of Round Maximum
    0.014*mm
    0.0005*in
    Taper -- Thrust Side Maximum
    0.020*mm
    0.0008*in
    Piston
    Diameter-Gaged on the skirt 12*mm below the centerline of the piston pin bore
    88.974-89.001*mm
    3.5029-3.5040*in
    Clearance
    0.032-0.068*mm
    0.0013-0.0027*in
    Pin Bore
    23.006-23.013*mm
    0.9057-0.9060*in
    Piston Ring
    Top Groove Side Clearance
    0.05-0.085*mm
    0.002-0.0033*in
    Second Groove Side Clearance
    0.05-0.09*mm
    0.002-0.0035*in
    Top Ring Gap
    0.15-0.36*mm
    0.006-0.014*in
    Second Ring Gap
    0.5-0.71*mm
    0.0197-0.0280*in
    Groove Clearance
    0.20*mm
    0.008 in*in
    Gap with segment at 89.0*mm
    0.25-1.27*mm
    0.0098-0.05*in
    Piston Pin
    Diameter
    22.9915-22.9964*mm
    0.9052-0.9054*in
    Clearance In Piston
    0.0096-0.0215*mm
    0.0004-0.0008*in
    Fit In Rod
    0.0165-0.0464*mm
    0.0006-0.0018*in
    Crankshaft
    Main Journal Diameter
    67.239-67.257*mm
    2.6473-2.6483*in
    Main Journal Taper
    0.005*mm
    0.0002*in
    Out Of Round
    0.005*mm
    0.0002*in
    Flange Runout-Max
    0.04*mm
    0.0016*in
    Cylinder Block Main Bearing Bore Diameter
    72.155-72.168*mm
    2.8407-2.8412*in
    Crankshaft Main Bearing Inside Diameter
    67.289-67.316*mm
    2.6492-2.6502*in
    Main Bearing Clearance
    0.019-0.064*mm
    0.0008-0.0025*in
    Main Thrust Bearing Clearance
    0.032-0.077*mm
    0.0012-0.0030*in
    Crankshaft End Play
    0.060-0.210*mm
    0.0024-0.0083*in
    Crankshaft Flange Runout-Max
    0.04*mm
    0.0016*in
    Crankpin
    Rod Bearing Journal Diameter
    50.768-50.784*mm
    1.9987-1.9994*in
    Rod Bearing Journal Taper
    0.005*mm
    0.0002*in
    Rod Bearing Journal Out Of Round
    0.005*mm
    0.0002*in
    Rod Bearing Bore Diameter
    53.962-53.984*mm
    2.124-2.125*in
    Rod Inside Bearing Diameter
    50.812-50.850*mm
    2.000-2.002*in
    Rod Bearing Journal Clearance
    0.018-0.062*mm
    0.0007-0.0024*in
    Rod Side Clearance
    0.18-0.44*mm
    0.007-0.017*in
    Camshaft
    Lobe Lift (Intake and Exhaust)
    6.9263*mm
    0.2727*in
    Journal Diameter
    47.45-47.48*mm
    1.868-1.869*in
    Camshaft Bearing Bore Diameter-Front and Rear
    51.03-51.08*mm
    2.009-2.011*in
    Camshaft Bearing Bore Diameter-Middle #2 and #3
    50.77-50.82*mm
    1.999-2.001*in
    Camshaft Bearing Inside Diameter
    47.523-47.549*mm
    1.871-1.872*in
    Journal Clearance
    0.026-0.101*mm
    0.001-0.0039*in
    Journal Runout-Max
    0.025*mm
    0.001*in
    Valve System
    Roller Lifter
    Hydraulic
    Rocker Arm Ratio
    1.60:1
    Valve Face Angle
    45°
    Seat Angle
    45°
    Valve Seat Runout
    0.025*mm
    0.001*in
    Seat Width-Intake
    1.55-1.80*mm
    0.061-0.071*in
    Seat Width-Exhaust
    1.70-2.0*mm
    0.067-0.079*in
    Valve Margin - Minimum Intake
    2.10*mm
    0.083*in
    Valve Margin - Minimum Exhaust
    2.70*mm
    0.106*in
    Valve Stem Clearance
    0.026-0.068*mm
    0.0010-0.0027*in
    Valve Spring
    Valve Springs Free Length
    48.5*mm
    1.89*in
    Valve Springs Load (Closed)
    320 N @ 43.2*mm
    75 lb @ 1.701*in
    Valve Springs Load (Open)
    1036 N @ 32*mm
    230 lb @ 1.260*in
    Installed Height Intake-Exhaust
    43.2*mm
    1.701*in
    Approx. # or coils
    6.55
    Oil Pump
    Gear Lash
    0.094-0.195*mm
    0.0037-0.0077*in
    Gear Pocket Depth
    30.52-30.58*mm
    1.202-1.204*in
    Gear Pocket Diameter
    38.176-38.226*mm
    1.503-1.505*in
    Gear
    Length
    30.45-30.48*mm
    1.199-1.200*in
    Diameter
    38.05-38.10*mm
    1.498-1.500*in
    Side Clearance
    0.038-0.088*mm
    0.001-0.003*in
    End Clearance
    0.040-0.125*mm
    0.002-0.005*in
    Valve to Bore Clearance
    0.038-0.089*mm
    0.0015-0.0035*in
    Fastener Tightening Specifications (L82)
    Application
    N·m
    Lb Ft
    Lb In
    Accelerator Control Cable Bracket Bolt
    14
    125
    Accelerator Control Cable Bracket Nut
    10
    89
    Camshaft Position Sensor Bolt
    10
    89
    Camshaft Sprocket Bolt
    110
    81
    Camshaft Thrust Plate Bolt
    10
    89
    Connecting Rod Cap Nut
    20 +75°
    15 +75°
    Coolant Drain Plug
    19
    14
    Coolant Outlet Bolt
    25
    18
    Coolant Pump Bolt
    10
    89
    Coolant Pump Pulley Bolt
    25
    18
    Crankshaft Balancer Bolt
    103
    76
    Crankshaft Oil Deflector Nut
    25
    18
    Crankshaft Position Sensor Bolt - Front Cover
    10
    89
    Crankshaft Position Sensor Bolt - Side of Blocks
    11
    98
    Cylinder Head Bolt
    45 +90°
    33 +90°
    EGR Adapter Pipe to Exhaust Manifold Nut
    25
    18
    EGR to Adapter Pipe Bolt
    25
    18
    Electronic Ignition Control Module Bracket Bolt
    25
    18
    Electronic Ignition Control Module Bracket Nut
    25
    18
    Engine Coolant Temperature Sensor
    23
    17
    Engine Mount Bracket Bolt
    58
    43
    Engine Mount to Bracket Nut
    47
    35
    Engine Mount to Frame Bracket Nut
    43
    32
    Engine Mount Strut Nut
    48
    35
    Engine Mount Strut Bracket Bolt - Engine Right Side
    50
    37
    Engine Mount Strut Bracket Bolt - Engine Left Side
    70
    52
    Engine Mount Strut Bracket Bolt - Upper Radiator Support
    26
    19
    Exhaust Crossover Pipe Nut
    25
    18
    Exhaust Crossover Pipe Heat Shield Bolt
    10
    89
    16
    12
    Exhaust Manifold Heat Shield Bolt
    10
    89
    Exhaust Manifold Stud
    16
    12
    Flywheel Bolt
    83
    61
    Front Cover Bolt - Large
    47
    35
    Front Cover Bolt - Small
    21
    15
    Fuel Injector Rail Bolt
    10
    89
    Fuel Pipe Bracket Bolt
    50
    37
    Fuel Pipe Bracket Stud
    50
    37
    Fuel Pipe Fitting
    17
    13
    Fuel Pipe Retaining Clip Bolt
    10
    89
    Generator Bracket Bolt
    50
    37
    Heater Inlet Pipe Nipple
    30
    22
    Heater Inlet Pipe Nut
    25
    18
    Heater Inlet Pipe Stud
    25
    18
    Knock Sensor
    19
    14
    Lower Intake Manifold Bolt
    13
    115
    MAP Sensor Bolt
    4
    36
    Oil Gallery Plug - 1/4 in
    19
    14
    Oil Gallery Plug - 3/8 in
    33
    24
    Oil Filter
    13
    115
    Oil Filter By-pass Plug
    19
    14
    Oil Filter Fitting
    39
    29
    Oil Filter Cooler Connector
    50
    37
    Oil Level Indicator Assembly Bolt
    25
    18
    Oil Level Sensor
    10
    89
    Oil Pan Retaining Bolt
    25
    18
    Oil Pan Side Bolt
    50
    37
    Oil Pan Drain Plug
    25
    18
    Oil Pressure Switch
    13
    115
    Oil Pump Bolt
    41
    30
    Oil Pump Cover Bolt
    10
    89
    Oil Pump Drive Assembly Bolt
    36
    27
    Rear Engine Lift Bracket Bolt
    50
    37
    Rocker Arm Bolt
    10 +30°
    89 +30°
    Rocker Cover Retaining Bolt (Finger Tighten All Bolts First)
    10
    89
    Spark Plug
    20
    15
    Throttle Body Bolt
    25
    18
    Timing Chain Dampener Bolt
    21
    15
    Upper Intake Manifold Bolt
    25
    18
    Upper Intake Manifold Stud
    25
    18
    Valve Lifter Guide Bolt
    10
    89
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Aftermarket 3500 LX9 Lower Intake Gaskets
      by SappySE107
      If you are replacing the lower intake gaskets for whatever reason, its most likely going to be a metal and rubber gasket, like this.
      which is great, if you only want it to seal. If you want it to make the power it use to, then you need to remove some of that rubber, like this.
      Then you throw it on a flowbench (or take my word for it since I did this step for WOT-Tech)
      And see what the flow difference is.
      03-22-2024, 02:40 AM
    • 3x00 Exploded View
      by bszopi
      Click on a number corresponding to the part you are looking for information on. This will load a new page with detailed information (part numbers, specifications, description, etc) for the part. This is a general breakdown of parts. With that said, there may be some parts not shown that are on a specific platform. There may also be some parts that are shown that are not on all platforms. Several items vary over the years as well, and any variances should be covered in the detailed description pa...
      10-07-2010, 12:46 AM
    • 3100 (Gen 3) Specifications : LG8
      by bszopi
      06-15-2010, 05:48 PM
      by bszopi
      06-15-2010, 05:42 PM
    • Pushrod Location
      by SappySE107
      Pushrods are valve specific on all Gen 2 and newer pushrod motors. The following are when you are standing in front of the radiator, looking at the engine. In a FWD configuration the order for the rear head from left to right is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust. The front head from left to right is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust. If you are working with a RWD configuration, the left head from front to back is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust...
      04-13-2010, 09:10 PM
