3.4L (DOHC) Specifications
  • 3.4L (DOHC) Specifications
    Application
    Millimeters
    Inches
    General Data
    Engine Type
    60° V-6
    Displacement
    204*Cu*In
    Liter (VIN)
    3.4 (X)
    RPO
    LQ1
    Bore
    92
    3.622
    Stroke
    84
    3.307
    Deck Height
    224
    8.818
    Compression Ratio
    9.50:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure @ Operating Temperature
    103*kPa @ 1100 RPM
    15*psi*min @ 1100 RPM
    Cylinder Bore
    Diameter
    92.020-92.038
    3.6228-3.6235
    Out Of Round Maximum
    0.010
    0.0004
    Taper -- Thrust Side Maximum
    0.013
    0.00051
    Center Distance
    111.76
    4.4
    Piston
    Diameter-gauged at skirt 10.44*mm (0.413*in) below centerline of piston pin bore
    91.985-92.000
    3.6215-3.6220
    Clearance
    0.020-0.052
    0.0008-0.0020
    Pin Bore
    23.003-23.010
    0.9056-0.9059
    Piston Ring
    Compression Groove Clearance 1st and 2nd
    0.033-0.079
    0.0013-0.0031
    Gap (at gauge diameter) 1st
    0.20-0.45
    0.008-0.018
    Gap (at gauge diameter) 2nd
    0.56-0.81
    0.022-0.032
    Oil Groove Clearance
    0.028-0.206
    0.0011-0.0081
    Gap (segment at gauge diameter)
    0.25-0.76
    0.0098-0.0299
    Tension 1st
    27.6*N
    6.2*lbs
    Tension 2nd
    19.8*N
    4.5*lbs
    Tension Oil
    31.2*N
    7.0*lbs
    Piston Pin
    Diameter
    22.9915-22.9964
    0.9052-0.9054
    Clearance
    0.0066-0.0185
    0.00026-0.00073
    Fit In Rod
    0.0165-0.0464
    0.0006-0.0018
    Crankshaft
    Main Journal Diameter-All
    67.239-67.257
    2.6472-2.6479
    Taper-Maximum
    0.005
    0.0002
    Out Of Round-Maximum
    0.005
    0.0002
    Cylinder Block Main Bearing Bore Diameter
    72.155-72.168
    2.8407-2.8412
    Crankshaft Main Bearing Inner Diameter
    67.289-67.316
    2.6492-2.6502
    Main Bearing Clearance
    0.019-0.064
    0.0008-0.0025
    Main Thrust Bearing Clearance
    0.032-0.077
    0.0013-0.0030
    Crankshaft End Play
    0.06-0.21
    0.002-0.008
    Crankpin
    Diameter
    50.768-50.784
    1.9987-1.9994
    Taper-Maximum
    0.005
    0.0002
    0.005
    0.0002
    Rod Bearing Bore Diameter
    53.962-53.984
    2.124-2.125
    Rod Inner Bearing Diameter
    50.812-50.850
    2.000-2.002
    Rod Bearing Clearance
    0.018-0.062
    0.0007-0.0024
    Rod Side Clearance
    0.18-0.44
    0.0071-0.0173
    Camshaft
    Lobe Lift (Intake)
    9.398 @ 108° Crank ATDC
    0.370 @ 108° Crank ATDC
    Lobe Lift (Exhaust)
    9.389 @ 115° Crank BTDC
    0.370 @ 115° Crank BTDC
    Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Right Bank
    TDC-1Piston Exhaust Stroke +/- 2° of Crankshaft
    Timing Reference Set Position with Camshaft Timing Flats in Clamped Position-Left Bank
    TDC-4 Piston Exhaust Stroke +/- 2° of Crankshaft
    Journal Diameter
    54.973-55.001
    2.1643-2.1654
    Bore Inside Diameter
    55.050-55.075
    2.1673-2.1683
    Journal Clearance
    0.049-0.102
    0.0019-0.0040
    Valve System
    Lifter
    Hydraulic
    Face Angle
    45°
    Seat Angle
    46°
    Seat Runout-Maximum
    0.075
    0.0030
    Seat Width Intake
    1.25-1.50
    0.0492-0.0591
    Exhaust
    1.60-1.90
    0.063-0.0748
    Valve Margin-Minimum
    0.75
    0.029
    Stem Clearance Intake
    0.028-0.066
    0.0011-0.0026
    Stem Clearance Exhaust
    0.046-0.084
    0.0018-0.0033
    Valve Spring
    Free Length
    42.04
    1.6551
    Load (Closed)-All
    289*N @ 35.56
    65*lb @ 1.400
    Load (Open)-All
    711*N @ 26.16
    160*lb @ 1.030
    Approximate Number of Active Coils
    4
    Oil Pump
    Valve to Bore Clearance
    0.038-0.089
    0.0015-0.0035
    Gear Lash
    0.094-0.195
    0.0037-0.0077
    Gear Pocket Depth
    30.53-30.61
    1.202-1.205
    Diameter
    38.202-38.252
    1.504-1.506
    Gear Length
    30.45-30.48
    1.199-1.20
    Diameter
    38.05-38.10
    1.498-1.50
    Side Clearance
    0.08-0.10
    0.003-0.004
    End Clearance
    0.05-0.152
    0.002-0.006
    3.4L (DOHC) Fastener Tightening Specifications
    Application
    N·m
    Lb Ft
    Lb In
    Accelerator Control Cable Bracket Bolt
    10
    89
    Accelerator Control Cable Bracket Nut
    10
    89
    Camshaft Carrier Cover Bolt
    11
    97
    Camshaft Carrier Thrust Plate Bolt
    10
    89
    Camshaft Carrier Thrust Plate Cover Bolt
    10
    89
    Camshaft Drive Belt Cover Bolt
    10
    89
    Camshaft Drive Sprocket Bolt
    130
    96
    Camshaft Housing Assembly Bolt
    27
    20
    Camshaft Position Sensor Bolt
    50
    37
    Connecting Rod Cap Nut
    20 +75°
    15 +75°
    Coolant By-Pass Nut
    25
    18
    Coolant Inlet Housing Bolt
    25
    18
    Coolant Outlet Bolt
    27
    20
    Coolant Pump Bolt
    11
    97
    Coolant Pump Pulley Bolt
    25
    18
    Crankshaft Balancer Mounting Bolt
    107
    79
    Crankshaft Main Bearing Cap Bolt
    50+75°
    37+75°
    Crankshaft Main Bearing Cap Stud
    50+75°
    37+75°
    Crankshaft Oil Deflector Nut
    25
    18
    Crankshaft Pulley-to-Crankshaft Damper Bolt
    60
    44
    Crankshaft Position Sensor Bolt-Front of Engine
    8
    71
    Crankshaft Position Sensor Bolt-Side of Engine
    8
    71
    Crankshaft Position Sensor Harness Retaining Bracket Bolt
    5
    45
    Cylinder Head Bolt
    60 +90°
    44 +90°
    Drive Belt Tensioner Bolt
    50
    37
    EGR Valve Adapter Brace Nut
    25
    18
    EGR Valve Adapter Stud
    10
    89
    EGR Tube Assembly
    25
    18
    EGR Valve Assembly Nut
    25
    18
    Electronic Ignition Control Module Assemble Bolt/Stud
    25
    18
    Electronic Ignition Control Assembly Nut
    25
    18
    Engine Block Coolant Drain Plug
    19
    14
    Engine Block Oil Gallery Plug-Center Rear
    16
    12
    Engine Block Oil Gallery Plug-Rear
    33
    24
    Engine Block Oil Gallery Plug-Side of Block
    19
    14
    Engine Coolant Temperature Sensor
    18
    13
    Engine Motor Mount Frame Nut-Engine Left Side
    43
    32
    Engine Motor Mount Bracket Nut-Engine Left Side
    43
    32
    Engine Motor Mount Frame Nut-Engine Right Side
    43
    32
    Engine Motor Mount Bracket Nut-Engine Right Side
    47
    35
    Engine Motor Mount Bracket -Front of Block Bolt-Engine Left Side
    103
    76
    Engine Motor Mount Bracket-Side of Block Bolts-Engine Left Side
    58
    43
    Engine Motor Mount Bracket-Front of Block Bolts-Engine Right Side
    102
    75
    Engine Motor Mount Bracket-Side of Block Bolt-Engine Right Side
    58
    43
    Engine Motor Mount Bracket-Transaxle Bolts-Engine Right Side
    75
    55
    Engine Mount Strut Bracket Bolt
    80
    59
    Engine Oil Cooler Connector
    40
    30
    Engine Oil Level Sensor
    22
    16
    Evaporator Emission Canister Purge Solenoid Mounting Bracket Bolt
    10
    89
    Exhaust Manifold Crossover Stud
    9
    80
    Exhaust Manifold Nut
    13
    116
    Exhaust Manifold Stud
    17
    13
    Flywheel Bolt
    82
    60
    Front Cover Coolant Drain Plug
    25
    18
    Front Cover Bolts- Large
    47
    35
    Front Cover Bolts - Small
    27
    20
    Front Cover-to-Front Engine Lift Hook Bolt
    25
    18
    Front Engine Lift Hook-to-Right Camshaft Carrier Bolt
    50
    37
    Front Engine Lift Hook-to-Right Cylinder Head Bolt (Access through Front Cover)
    50
    37
    Fuel Pipe Clip Bolt
    7
    62
    Fuel Pipe Retainer Screw
    3
    27
    Fuel Rail Assembly Bolt
    10
    89
    Ignition Coil Bolt
    25
    18
    Ignition Coil Nut
    25
    18
    Intermediate Drive Shaft Retainer Screw
    10
    89
    Intermediate Shaft Belt Sprocket Bolt
    130
    96
    Knock Sensor
    21
    15
    Lower Intake Manifold Mounting Bolt
    13
    116
    Manifold Absolute Pressure Sensor Bracket Bolt
    8
    71
    40
    30
    Oil Cooler Hose Fitting
    25
    18
    Oil Distribution Cover Bolt
    27
    20
    Oil Filter
    16
    12
    Oil Filter Fitting
    67
    49
    Oil Level Indicator Bolt
    10
    89
    Oil Pan Bolt-Except Rear
    11
    97
    Oil Pan Bolt-Rear (2)
    27
    20
    Oil Pan Drain Plug
    25
    18
    Oil Pan Nut
    11
    97
    Oil Pan Stud-to-Cylinder Block
    10
    89
    Oil Pressure Switch
    32
    24
    Oil Pump Cover Bolt
    10
    89
    Oil Pump Drive Clamp Bolt
    36
    27
    Oil Pump-to-Rear Main Cap Bolt
    54
    40
    Power Brake Booster Vacuum Pipe Fitting
    18
    13
    Rear Engine Mount Strut Bracket Bolt
    82
    60
    Secondary Air Injection Pipe
    25
    18
    Secondary Air Injection Pipe Nut-Left Side
    25
    18
    Secondary Air Injection Pipe Support Bolt
    10
    89
    Secondary Air Injection Pipe Nut-Right Side
    10
    89
    Serpentine Drive belt tensioner bolt
    50
    37
    Spark Plug
    20
    15
    Throttle Body Adapter Bolt
    25
    18
    Throttle Body Adapter Nut
    25
    18
    Throttle Body Heater Outlet Hose Nipple
    18
    13
    Throttle Body Stud
    4
    36
    Throttle Body Bolt
    10
    89
    Tie Bar Bracket
    26
    19
    Timing Belt Cover Bolt
    10
    89
    Timing Belt Idler Pulley Bolt
    50
    37
    Timing Belt Tensioner Actuator Bracket Bolt
    50
    37
    Timing Belt Tensioner Actuator Pulley Pivot Bolt
    50
    37
    Timing Belt Tenisoner Actuator Side Plate Bolt
    27
    20
    Timing Chain Tensioner Bolt
    27
    20
    Engine Mount Strut and Engine Lift Bracket Bolt
    70
    52
    Upper Intake Manifold Retaining Bolt
    26
    19
    Water Inlet Fitting to Front Cover
    27
    20
    Vacuum Source Manifold Mounting Bolt
    7
    62
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • LQ1 Service Bulletin 57-61-09 Lifter tick (cold)
      by Schurkey
      Dug up the GM Service Bulletin for "Lifter tick when cold", 57-61-09. '91 to '95 LQ1 (VIN X) (mymonte.com is gone) The parts kit has been discontinued by GM long ago. My quest was to find sources for those parts; and complete the procedure on my '93 Lumina Euro 3.4 which was torn apart to replace the rear head gasket. There are three critical part numbers in the GM service kit (aside from gaskets and O-rings) required to perform this operation. Two of the three are readily available in the afterm...
      03-02-2012, 02:48 PM
    • 3.4 DOHC Heads on a 3x00 Block
      by bszopi
      Several people have talked about the possibility to use the 3.4 DOHC heads on the 3x00 engines. Some for performance, and some for replacment, where getting a 3.4 DOHC block might be difficult, but getting a 3400 (or even a 3100) block might be easier to come by. For these test fittings, I used a 1994 3.4 DOHC BLOCK, a 1994 3.4 DOHC REAR head, a 1999 3100 SFI BLOCK, and a 1996 3100 SFI head. This article is broken into 3 sections. The first section is BASIC COMPARISONS where I compare the BLOCK o...
      01-20-2011, 12:08 PM
      by bszopi
      06-15-2010, 05:56 PM
    • OBD2 Tuning 3.4 DOHC
      by Dave96z34
      The 97 4T65 in the Monte Carlo is almost bullet proof. I have been beating the crap out of my reman with my blower now for 2.5 years of daily driving vs the 60 NA that I couldn't get 1 year out of. 4 Trans in 50K miles. I'm a violent offender. Overfilling and royal purple atf are my secret. DHP will do 96 and 97 DOHC tuning, HPTuners only works with the 97 computer. 96 can not change line pressure, 97 can. 97 bin is double in size of the 96 bin. They changed every thing and it has every ...
      04-17-2010, 04:53 AM
    • 3.4 DOHC Pistons
      by SappySE107
      Here is the TRW catalogue spec sheet for the 91-95 as well as the 96/97 pistons.
      TRW 3.4 DOHC Pistons
      Silvolite 3.4 DOHC Pistons Notice that the 96-97 pistons don't have as much compression distance but also have a dome to them. I dont know the exact amount of compression loss you will get when using these pistons with the 91-95 heads, but it goes against the common belief that 96 pistons raise compression. The Silvolite pistons are the EXACT pistons used in the 91-
      04-14-2010, 01:23 AM
    • 96/97 3.4 DDOHC Intake Manifold Swap for 91-95 Engines
      by OldSkoolGP
      Pictures can befound here * Need to find this album *
      http://60degreev6.com/gallery/browseimages.php?c=27 Having just completed this swap myself and being MORE than impressed with the results, I felt the need to write up how to properly do this swap so everyone else can do it easily: First off, here are the major components you will need from your donor motor: Upper Intake (Plenum) Lower Intake and fuel rail ’96 Rear Cam Carrier Cover (Valve Cover) Intake pipe Throttle Bo...
      04-14-2010, 01:20 AM
