91-95 Plenum Removal
  • 91-95 Plenum Removal
    I did this on a 94-95 engine but aside from a few minor vacuum lines the instructions should work.
    1. remove the plastic engine cover
    2. unbolt the plenum to lower intake 10mm bolts
    3. take the 2 rear mount nuts off, they are on the rear of the plenum by the spark plug wires
    4. take the intake arm/tube and airbox/cone filter off
    5. unhook the cables from the throttle body. It is easiest if you slide the plastic clips off of the metal mount.
    6. take the 2 small screws holding the metal transmission vacuum line to the fuel rail (I did not put these back on)
    7. pull the metal vacuum line and the plastic line off of the plenum (91-93 may have a different setup)
    8. remove the 2 vacuum lines from right behind the throttle body
    9. take the small screw and clamp off that clamp the fuel lines to the throttle body bracket (I did not put this back on)
    10. Now the fun part, slide the top hose clamp from the coolant line out of the bottom of the throttle body down to the bottom. A small pair of vice grips work nicely.
    11. Make sure I did not miss anything, use common sense here
    12. Pull up on the plenum. It takes some force to pull the throttle body barb out of the coolant hose.
    13. Once you get the plenum up some remove the brake booster hose from the rear of the plenum.
    Replace your plenum to lower intake gasket while you are at it.
    *Pictures no longer available*
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • LQ1 Service Bulletin 57-61-09 Lifter tick (cold)
      by Schurkey
      Dug up the GM Service Bulletin for "Lifter tick when cold", 57-61-09. '91 to '95 LQ1 (VIN X) (mymonte.com is gone) The parts kit has been discontinued by GM long ago. My quest was to find sources for those parts; and complete the procedure on my '93 Lumina Euro 3.4 which was torn apart to replace the rear head gasket. There are three critical part numbers in the GM service kit (aside from gaskets and O-rings) required to perform this operation. Two of the three are readily available in the afterm...
      03-02-2012, 02:48 PM
    • 3.4 DOHC Heads on a 3x00 Block
      by bszopi
      Several people have talked about the possibility to use the 3.4 DOHC heads on the 3x00 engines. Some for performance, and some for replacment, where getting a 3.4 DOHC block might be difficult, but getting a 3400 (or even a 3100) block might be easier to come by. For these test fittings, I used a 1994 3.4 DOHC BLOCK, a 1994 3.4 DOHC REAR head, a 1999 3100 SFI BLOCK, and a 1996 3100 SFI head. This article is broken into 3 sections. The first section is BASIC COMPARISONS where I compare the BLOCK o...
      01-20-2011, 12:08 PM
    • 3.4L (DOHC) Specifications
      by bszopi
      06-15-2010, 05:56 PM
    • OBD2 Tuning 3.4 DOHC
      by Dave96z34
      The 97 4T65 in the Monte Carlo is almost bullet proof. I have been beating the crap out of my reman with my blower now for 2.5 years of daily driving vs the 60 NA that I couldn't get 1 year out of. 4 Trans in 50K miles. I'm a violent offender. Overfilling and royal purple atf are my secret. DHP will do 96 and 97 DOHC tuning, HPTuners only works with the 97 computer. 96 can not change line pressure, 97 can. 97 bin is double in size of the 96 bin. They changed every thing and it has every ...
      04-17-2010, 04:53 AM
    • 3.4 DOHC Pistons
      by SappySE107
      Here is the TRW catalogue spec sheet for the 91-95 as well as the 96/97 pistons.
      TRW 3.4 DOHC Pistons
      Silvolite 3.4 DOHC Pistons Notice that the 96-97 pistons don't have as much compression distance but also have a dome to them. I dont know the exact amount of compression loss you will get when using these pistons with the 91-95 heads, but it goes against the common belief that 96 pistons raise compression. The Silvolite pistons are the EXACT pistons used in the 91-
      04-14-2010, 01:23 AM
    • 96/97 3.4 DDOHC Intake Manifold Swap for 91-95 Engines
      by OldSkoolGP
      Pictures can befound here * Need to find this album *
      http://60degreev6.com/gallery/browseimages.php?c=27 Having just completed this swap myself and being MORE than impressed with the results, I felt the need to write up how to properly do this swap so everyone else can do it easily: First off, here are the major components you will need from your donor motor: Upper Intake (Plenum) Lower Intake and fuel rail ’96 Rear Cam Carrier Cover (Valve Cover) Intake pipe Throttle Bo...
      04-14-2010, 01:20 AM
