2.8L (Gen 2) Specifications
  • 2.8L (Gen 2) Specifications
    General Data: All dimensions are in millimeters
    Type
    60 degree V6
    Displacement
    2.8L
    RPO
    LB6
    Bore
    89.0
    Stroke
    76.0
    Deck Height
    224
    Compression Ratio
    8.9:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    69 kPa @500 RPM; 205-380 kPa @ 2000 RPM
    (10 psi @ 500 RPM; 30-55 psi @ 2000R RPM)
    Cylinder Bore:
    Diameter
    88.983-89.017
    Out of Round
    0.013 (Maximum)
    Taper - Thrust Side
    0.013 (Maximum)
    Piston:
    Clearance
    0.023-0.056
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.051.089
    Second
    0.051.089
    Gap
    Top
    0.25-0.50
    Second
    0.25-0.50
    OIL
    Groove Clearance
    0.199 (Maximum)
    Gap
    0.25-076
    Piston Pin:
    Diameter
    22.992-22.997
    Clearance
    0.0064-0.0091
    Fit in Rod
    Press
    Crankshaft:
    Main
    Journal
    Diameter
    67.241-67.267
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing Clearance
    0.030-0.069
    Crankshaft End Play
    0.05-0.20
    Crankpin
    Diameter
    50.757-50.785
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing Clearance
    0.036-0.091
    Rod Side Clearance
    0.36-0.68
    Camshaft:
    Lift
    Intake
    6.67
    Exhaust
    6.93
    Journal Diameter
    47.442-47.790
    Journal Clearance
    0.02-0.10
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle (Intake & Exhaust)
    45 degrease
    Seat Angle (Intake & Exhaust)
    46 degrease
    Seat Runout (Intake & Exhaust)
    0.02
    Seat Width
    Intake
    1.55-1.85
    Exhaust
    1.70-2.01
    Stem Clearance
    0.025-0.069
    Valve Spring
    Free Length
    48.51
    Pressure
    Kg @ mm
    Closed
    40.8 @ 43.2
    Open
    97 @ 32.79
    Installed Height
    40.01
    Valve Spring
    Damper
    Free Length
    48.51
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Camshaft Sprocket Bolts
    24
    18
    Connecting Rod Bolt Nuts
    51
    37
    Crankshaft Damper Bolt
    77
    104
    Cylinder Head Bolt (apply thread sealant to bolts)
    First Pass
    45
    33
    Final Pass Add 90 Degrees
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    Exhaust Manifold Bolt
    24
    18
    Flywheel Bolt
    71
    52
    Front Timing Cover Case Bolt
    8mm 18-35 13-25
    10mm 27-47 20-35
    Lower Intake Manifold Bolt
    First Pass 22 16
    Final Pass 31 23
    Upper Intake Manifold Bolt
    22
    16
    Main Bearing Cap 99 73
    Oil Pan Bolt
    6mm
    8-12
    6-9
    8mm 19-30 14-22
    Oil Pump Bolt
    41
    30
    Rocker Arm Nut
    24
    18
    Timing Chain Damper Bolt
    20
    15
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Gen 2 Flowsheets
      by SappySE107
      Might be a work in progress? Lets just get started and see where it goes. 28", 3.700" bore. PAP % 100cfm +5% 200cfm +1% 300cfm +1%
      Starting off with the bare head, using clay to bellmouth the port inlet.
      Next we will put the intake manifolds on, with the throttle body and all vac ported blocked and untested ports taped off. This shows flow distribution between all runners.
      This is the comparison sheet for the middle port using...
      08-18-2024, 12:04 PM
    • Using an adjustable pushrod for lifter preload
      by SappySE107
      Our engines use non adjustable rocker arms, so pushrod length is import to lifter preload, which is important for performance. Incorrect preload does change power on the dyno, or in extreme cases, the ability to run well or at all.
      There are 2 options for the adjustable pushrods, a shorter option custom made for wot-tech for use on 3100/3400/3500 LX9 engines. These measure below 5.700", which is very short for an automotive engine. The other option is a Comp pushrod that measures...
      07-18-2024, 12:29 AM
    • Gen 2 to Gen 3 Top-End Swap
      by bszopi
      The 3100 and 3400 engines are called Gen 3, because they are the third generation pushrod 60V6 engines. The reason for the swap is simple. Flow and design, both of which the Gen 3 triumphs all previous generations. The iron heads don't have splayed valves, D shaped exhaust ports, or in some cases even the larger valves (1.42/1.72). The Gen 2 Aluminum head engines are the most popular to do this swap, but no matter what you start with, the same steps apply. The Gen 3 parts have D shaped exhaust po...
      11-16-2010, 11:53 PM
    • 3.1L (Gen 2) Specifications
      by bszopi
      06-15-2010, 05:25 PM
      by bszopi
      04-21-2010, 08:18 PM
