3.4L (Gen 1) Specifications
  • 3.4L (Gen 1) Specifications
    General Data: All dimensions are in millimeters
    Type
    60 degree V6
    Displacement
    3.4L
    RPO
    L32
    Bore
    92.0
    Stroke
    84.0
    Deck Height
    224
    Compression Ratio
    9:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    69 kPa @500 RPM; 205-380 kPa @ 2000 RPM
    (10 psi @ 500 RPM; 30-55 psi @ 2000R RPM)
    Cylinder Bore:
    Diameter
    92.020-92.038
    Out of Round
    0.007 (Maximum)
    Taper - Thrust Side
    0.007 (Maximum)
    Maximum Deck Warpage
    0.10
    Piston:
    Clearance
    0.028-0.061
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.050-0.090
    Second
    0.050-0.090
    Gap
    Top
    0.18-0.41
    Second
    0.48-0.074
    OIL
    Groove Clearance
    0.20(Maximum)
    Gap
    0.25-0.76
    Piston Pin:
    Diameter
    22.992-22.996
    Clearance
    0.012-0.022
    Fit in Rod
    0.017-0.046
    Crankshaft:
    Main
    Journal
    Diameter
    67.239-67.257
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing Clearance
    0.032-0.077
    Crankshaft End Play
    0.05-0.2
    Crankpin
    Diameter
    50.768-50.786
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing Clearance
    0.028-0.081
    Rod Side Clearance
    0.18-0.44
    Camshaft:
    Lift
    Intake
    6.67
    Exhaust
    6.94
    Journal Diameter
    Journals
    47.44-47.52
    Journal Clearance
    0.03-0.10
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle (Intake & Exhaust)
    45 degrees
    Seat Angle (Intake & Exhaust)
    46 degrees
    Margin
    Exhaust
    1.55-1.85
    Intake
    170-2.01
    Runout
    0.3
    Stem Clearance
    0.2-.0.8
    Valve Spring
    Free Length
    48.5
    Pressure
    Kg @ mm
    Closed
    36 @ 40.9
    Open
    84 @ 30.5
    Installed Height
    40.9
    Valve Spring
    Damper
    Free Length
    48.5
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Camshaft Sprocket Bolt 24 18
    Connecting Rod Cap Nut 50 37
    Crankshaft Damper Bolt 78 58
    Cylinder Head Bolt (In Sequence) (apply thread sealant to bolts)
    First Pass 55 41
    Final Pass Add 90 degrees
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    Exhaust Manifold Bolt 24 18
    Flexplate/Flywheel Bolt 83 61
    Front Timing Cover Case Bolt
    8mm 27 20
    10mm 38 28
    Lower Intake Manifold (In Sequence)
    First Pass 20 15
    Final Pass 30 22
    Upper Intake Manifod Bolt 25 18
    Main Bearing Cap Bolt
    First Pass 50 37
    Final Pass Add 77 degrees
    Oil Filter Adapter 68 50
    Oil Pan Rear Bolts 25 18
    Oil Pan Bolt and Nut (Except Rear 2) 10 8
    Oil Pump Bolt 41 30
    Rocker Arm Stud 46 35
    Belt Tensioner 33 24
    Throttle Body Bolts 25 18
    Timing Chain Damper Bolt 25 18
    Water Pump Pulley Bolt 24 18
    Water Pump 24 18
    Large 47 35
    Medium 21 15
    Small 10 8
    Exhaust Heat Shield Nut 9 8
    Valve Cover Bolt 8 7
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
