General Data: All dimensions are in millimeters |
Type |
60 degree V6 |
Displacement |
2.8L |
RPO |
LL2 |
Bore |
89.0 |
Stroke |
76.0 |
Deck Height |
224 |
Compression Ratio |
8.9:1 |
Firing Order |
1-2-3-4-5-6 |
Oil Pressure |
69 kPa @500 RPM; 205-380 kPa @ 2000 RPM (10 psi @ 500 RPM; 30-55 psi @ 2000R RPM) |
Cylinder Bore: |
Diameter |
88.992-89.070 |
Out of Round |
0.02 (Maximum) |
Taper - Thrust Side |
0.02 (Maximum) |
Piston: |
Clearance |
0.017-0.043 |
Piston Ring: |
COMPRESSION |
Groove Clearance |
Top |
0.030-0.070 |
Second |
0.040-0.095 |
Gap |
Top |
0.25-0.50 |
Second |
0.25-0.50 |
OIL |
Groove Clearance |
0.199 (Maximum) |
Gap |
0.27-1.25 |
Piston Pin: |
Diameter |
22.9937-23.0015 |
Clearance |
0.0065-0.0091 |
Fit in Rod |
0.0187-0.0515 (Press) |
Crankshaft: |
Main Journal |
Diameter - 3 Dots |
67.241-67.249 |
Diameter - 2 Dots |
67.249-67.257 |
Diameter - 1 Dot |
67.257-67.265 |
Taper |
0.005 (Maximum) |
Out Of Round |
0.005 (Maximum) |
Main Bearing Clearance |
0.032-0.069 |
Crankshaft End Play |
0.06-0.21 |
Crankpin |
Diameter - 2 Dots |
50.758-50.771 |
Diameter - 1 Dot |
50.771-50.784 |
Taper |
0.005 (Maximum) |
Out of Round |
0.005 (Maximum) |
Rod Bearing Clearance |
0.028-0.083 |
Rod Side Clearance |
0.36-0.60 |
Camshaft: |
Lift |
Intake |
6.65 |
Exhaust |
6.94 |
Journal Diameter |
47.44-47.49 |
Journal Clearance |
0.026-0.101 |
Valve System: |
Lifter |
Hydraulic |
Rocker Arm Ratio |
1.50:1 |
Valve Lash |
Intake |
1-1/2 Turns Down from Zero Lash |
Exhaust |
Face Angle (Intake & Exhaust) |
45 degrease |
Seat Angle (Intake & Exhaust) |
46 degrease |
Seat Runout (Intake & Exhaust) |
0.05 |
Seat Width |
Intake |
1.25-1.50 |
Exhaust |
1.60-1.90 |
Stem Clearance |
0.026-0.068 |
Valve Spring |
Free Length |
48.5 |
Pressure N @ mm |
Closed |
391 @ 40 |
Open |
867 @30 |
Installed Height |
40 |
Valve Spring Damper |
Free Length |
*47.2 |
Approx # of Coils |
4 |
Fastener Tightening Specifications
Item |
Nm |
Ft Lbs |
Air Injection Tube |
34 |
25 |
Air Injection Tube Nut |
25 |
18 |
Camshaft Sprocket Bolts |
23 |
17 |
Connecting Rod Bolt Nuts |
53 |
39 |
Coolant Outlet Bolts |
21 |
15 |
Coolant Pump Bolts (M6 x 10) |
10 |
7 |
Coolant Pump Bolts (M8 x 125) |
24 |
18 |
Coolant Pump Nut |
10 |
7 |
Cylinder Head Bolts (In Sequence) |
95 |
70 |
*Manifold Side* 6 2 3 7 5 1 4 8 * Outer Side * * |
EGR Valve |
25 |
18 |
Exhaust Manifold Bolts |
34 |
25 |
Front Cover Bolts | * | |
*** -10mm Bolt (4) |
50 |
37 |
*** -8mm Bolt (6) |
30 |
22 |
Flywheel Bolts |
70 |
52 |
Intake Manifold Bolts (In Sequence) |
21 |
15 |
H D A E I < Front G C B F J |
Main Bearing Cap Bolts |
95 |
70 |
Oil Filter Adapter |
85 |
63 |
Oil Pump Bolt |
41 |
30 |
Oil Pan Bolts (Rear Two) |
25 |
18 |
Oil Pan Bolts, Studs and Nuts |
10 |
7 |
Oil Pan Drain Plug |
25 |
18 |
Oil Pump Cover Screws |
9 |
7 |
Rocker Arm Cover Bolts |
8 |
6 |
Rocker Arm Studs |
65 |
48 |
Spark Plugs |
30 |
22 |
Timing Chain Damper |
21 |
15 |
Tortional Damper Bolt |
95 |
70 |
