3400 parts for sale
  • gpse3400
    • 1460
    3400 parts for sale
    Due to the failure of my engine I've deceided to part it out. Not only that I few new parts for sale as well. All sales are final.
    The new parts I want whatever Rock auto wants minus 10%.
    Felpro GEN3 Exhaust manifold gaskets
    Felpro GEN3 Converison set
    Sealed Power Timing Chain Damper
    Used parts
    GEN3 Timing Set low milage
    GEN 3 roller rocker arms
    GEN 3 Reman Cylinder heads with LS6 Valve springs(30K miles)
    GEN 3 Oil Pump
    GEN 3 Oil Pan with sensor
    GEN3 Large Port Ported lower intake manifold
    GEN3 Rocker covers
    GEN3 3400 block, needs new cam bearings
    GEN1 3.4 Sealed Power pistons on Connecting rods
    Lorenzo
  • CobraCDR
    • Apr 2005
    • 272
    I'll give you a ^^^^ for good stuff
    2004 Black Cobra Vert
    New Best Time 9-2-07: 1.81 60' 12.06 @ 117.3 Mph
    455 rwhp/ 458 rwtq
    1988 Pontiac Grand Prix SE - New Setup: Stock 3400 with 52 k on it from a 05 Impala, 255 walbro, LC-1 WB, Spec 3 Clutch, CS144 Alternator upgrade, DIY tune
    1989 Pontiac Turbo Grand prix - 44 k original miles, birchtrax'ed & intrax'ed, crane 2020, Topgun 160 +++ my own special herbs and spices
    • strtrydr
      • Apr 2006
      • 81
      what you want for the Oil Pan? I need one for my turbo project. Questions though my 3400 is a '00 model that is in a alero ... that pan should bolt up perfectly right?
      Thanks ... and dibs for now.
      • RedBird
        Aka Mr. 5th Motor
        • Sep 2006
        • 426
        What all is included in the "conversion" gasket set? and how much? IIRC it's the kit to replace the LIM gasket, but what all pieces are in there?
        Cammed 3400 --> 224whp 210wtq
        Cammed 3500 --> ???
        1 of 5 3500 J-Bodies
        • mfuller
          Mr. Common Sense
          • Nov 2003
          • 374
          Do the roller rockers have the older 10mm studs or the newer 8mm?
          Matt
          • gpse3400
            • 1460
            I'll take $40 shipped for the oil pan. It'll fit your year
            The rockers are the 10 mm stud stamped steel roller.
            Conversion set includes everything to seal up the bottom end including front cover gaskets. $35 shipped.
            Lorenzo
            • strtrydr
              • Apr 2006
              • 81
              cool man ... as soon as I get the money from selling my UIM, I will Paypal you; Consider it sold!!!
              Thanks In Advance.
              • gpse3400
                • 1460
                Lorenzo
                • Sardonyx
                  • 3
                  Are the 3.4L pistons forged? and are they any size over? The gen 1 is the Iron head correct?
                  • gpse3400
                    • 1460
                    they are cast. Sealed Power brand pistons. Stock diameter, they are for the Iron head GEN 1 3.4 camaro/firebird engine.
                    Lorenzo
                    • strtrydr
                      • Apr 2006
                      • 81
                      money on hand for Oil Pan need PayPal address ... I'll PM you the shipping address to use.
                        i'd consider the block if you weren't in new york.
                        • gpse3400
                          • 1460
                          Sold exhaust gaskets and timing damper.
                          Lorenzo
                          • strtrydr
                            • Apr 2006
                            • 81
                            ^we still go for that Oil Pan?
                            • Blazer406
                              • Jun 2007
                              • 17
                              I'll give you $20 shipped for all the hydraulic roller lifters.
