4T60E 4 Sale
  • gpse3400
    • 1460
    4T60E 4 Sale
    I have my rebuilt 4T60E for sale. Has only 10,000 miles on it. The rebuild in cludes new clutches, seals, Soliniods, switches, pump shaft, Drive chain, and HD thrust washers and bearings. Also has a trans go shift correction kit, 3.73 final drive, Phantom grip LSD, later model reinforced final drive housing, and fully shimmed 1-2 2-3 accumulators. This is a working unit and that shifts positive and true. Its set up for W bodies with a 3.1 or 3.4 TDC. Excellent gear box.
    Would like $400.
    Lorenzo
  • loner666
    • Oct 2006
    • 435
    what year is it?
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
      • 13522
      91-93. This trans shifts awesome, partial or full throttle.
      • 85_305
        • Feb 2007
        • 350
        Its an E with only being a '91-'93??
        '93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
        I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
        camaromanmatt@yahoo.com
          • 13522
          maybe im wrong but I think he has only had 91-93 setups. 3.4 DOHC came with a 4T60-E in 91-93 and 3.1 w body in 93.
          • gpse3400
            • 1460
            Yeah its really only good for '91-'93 3.4 TDC and '93 3.1. Ben is right, that gear box kicks ass.
            Lorenzo
            • 85_305
              • Feb 2007
              • 350
              Ahhh ok. Whats so good about the E though? How does it shift better?
              • gpse3400
                • 1460
                E mean its electronicall controled. In this transmissions case, the shifting and torque converter clutch are enabled electronically by the computer, from input of various sensors. The shift correction kit, shimmed accumulators new clutches and thr adjustment of the transmission modulator give it a crisp shift. With a strong enough engine it'll break the tires free on a WOT 1-2 shift.
                Lorenzo
                • 85_305
                  • Feb 2007
                  • 350
                  Whoa cool! So I'm assuming you mean a not-stock 3.1 or 3.4 for breaking the tires loose on the 1-2?
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    i thought they would work in a 94-95 lq1 car as well, just change out that little black box on top of the tranny(the one that tells the ecm which gear the car is in).
                    • tijuana_no
                      • Aug 2005
                      • 261
                      how does the phantom grip lsp work's in dayly driving on mostly on making quik turns (i heard there is a down side to them is that true).you don't happen to have a torque cornvter to go with it.
                      if you don't sale it soon or before i take care of some bills , i'll take it from you .
                      i just love to watch the wheels turn around and around
                      • gpse3400
                        • 1460
                        in '94 they added the PWM solinoid and deleted the 2 pressure switches.. You can wire it up so that it shifts and the tcc works for '94 +. you just wont use the switches. The phantom grip works well mainly at the track so I've noticed. You wont feel anything in the steering and it's perfectly safe. I actually I have 3 torque converters.. they all work and are all the same...take'em...The only thing that is wrong, with the trans is the side cover gasket seep a touch. I have a new gasket for it and a spare side cover.Yeah you start plumbing some power through it it'll perform.
                        Lorenzo
                        • tijuana_no
                          • Aug 2005
                          • 261
                          thanx , if you don't sell it in a good time frame that you want p.m. and i see how i'm going in my bills.but, i'am intrested cause i wanna re-built my 3.4 dohc engine that i blew and it;ll be nice to have a trannie ready for it also.
                          • gpse3400
                            • 1460
                            Well I was hopeing for somone one local as freight is going to be a nightmare....
                            Lorenzo
                              • 9189
                              Check out www.uship.com , as you might be able to find someone willing to haul it for relatively cheap.
