5 speed swap for a v6 alero?
  • alerojim01
    • Nov 2006
    • 6
    does anyone have a complete lisgt and or part numbers for a 5 speed swap into a V-6 alero? any hel appreciated
  • Kardain
    • Nov 2006
    • 111
    Here's what I know...
    The 1995-1997 2.2l J-Body (Cavalier/Sunfire) 5 speed MK7 -- aka Isuzu -- transmission will bolt right up to the 3400. You will need the shifter and cables from that car as well. Also, the clutch reservoir and piping, clutch pedal, flywheel, slave cylinder (it's internal) and clutch plates.
    From there, not sure about CV axles if you will need 94-98 N-Body or if the J-Body ones will work. The tranny mounts will need to be changed. Your ECU will need to be reflashed to remove all auto trans settings. As for the rest of the details, I'm not sure...
    • sharkey
      • Jun 2004
      • 2061
      i would stay away from the isuzu 5 speed myself. they are alright with a 4 cyl, but many people have diff problems as well as other breakage issues with a highly modded 4 cyl, so you can imagine what a v6 would do.
      i would go with a 92-94 getrag 5 speed from a j-body v6, or a 2000-2002 getrag from a 2.2l j-body. either will bolt right up, and they are both good transmissions.
      • TurboAlero
        TurboAlero
        • Jun 2006
        • 136
        MM Have don that swap so I the list is as following:
        A getrag from a 2001 sunfire or alero/grand am is ok because they can with stand more power than the Isuzo one.MM just use all of the part from a manual alero/grand am( Clutch padel, shifter and cabels from the same gearbox, flywheel, and all the other stuff. It's much easier to do this swap if you get like all the parts from a 2.4 alero/grand am.
        And when you're finishi with that you need to reflash and retune you're ECU.
        • TurboAlero
          TurboAlero
          • Jun 2006
          • 136
          I'm using the getrack gearbox from a berretta that came with the 3.1 v6 so it's a HM-282. MMm all other things like shifter cables most be costume where the cables hook up with the gearbox is diffrent
          • Kardain
            • Nov 2006
            • 111
            I'd go this route myself, but since my car's already a manual....
            As far as the breakage goes, from what I've read, its usually third gear that dies. The diff can be swapped for one out of a Geo Storm (forged diff) if it should happen to break. The gearing can be changed up a bit as well...
            However the route you want to take, theres the above options (and I'm sure there are more). Just whatever you decide, make sure you get all the parts you can out of the donor vehicle.
            • sharkey
              • Jun 2004
              • 2061
              just keep in mind that a 2.4l tranny or an ecotec tranny will not bolt up to our motors. you need the getrag from a 2000-2002 j-body 2.2/2200. everything else is exactly the same on the tranny compared to a 2.4/ecotec, so mounts and such can come from a 2.4 alero/grand am
              • TurboAlero
                TurboAlero
                • Jun 2006
                • 136
                I didn't know that , but does the 2.4 engine in the alero/grand am come with the 4t40E tranny?
                it's the same tranny I think that come's with the 3.4 ( same housing ) because the 3.4 came with the 4t45E
                • camaroguy
                  • Nov 2006
                  • 17
                  might have different housings.
                  • Kardain
                    • Nov 2006
                    • 111
                    Correct.
                    • sharkey
                      • Jun 2004
                      • 2061
                      the 4t40e comes behind the 2.4l as well as the 3400. they are however a different bellhousing.
                      • onefastV6
                        • Sep 2005
                        • 880
                        5 speed N bodys are somewhat difficult to locate. I currently have most of the parts needed to swap to a 5 speed but lack of time and a place have me thinking of selling what I have.
                        Some of my info can be found here:
                        2000 Grand Am GT
                        2011 Chevy Impala
                        • alerojim01
                          • Nov 2006
                          • 6
                          let me know what you want for the stuff if you do go that route. what flywheel do i need to use? one from a 3.1 car?
                          • Kardain
                            • Nov 2006
                            • 111
                            One from whatever car you get the tranny from (just to make sure the clutch works properly)
                            • alerojim01
                              • Nov 2006
                              • 6
                              will a 96-99 cavalier 5 speed work? Im really desperate and need a trans fast!
