3100 gasket on 3500 head
    • 13520
    I found a 3100 gasket and took some pictures of it on the 3500 head.
    The fire ring overlaps the combustion chamber on the intake and exhaust areas. Not much, certainly not the width of the fire ring but I don't think this is a good way to be. I am not sure what will happen if you use a 3400 gasket on a bored over 3100.
    • 13520
    I used some clay to form around it and its .025" overlapped.
    • Chris88CL
      Moderator
      • Dec 2003
      • 212
      I want to see a 3400 gasket on the 3500 heads.
        • 13520
        I have a 3.4 DOHC gasket, which is the same thing as far as bolt pattern and bore goes.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Any for a 3.1MPFI block with 3500 swap combo? Or is that very much the same for the 3100/3500?
            • 13520
            Thats the same thing as 3100. 2.8/3.1/3100 use the same bore.
            • Scott_68B
              • Nov 2003
              • 147
              This is excellent information. Do you think that we're better off not going with 3500 heads on a stock 3.1/3100?
              -- Scott
                • 13520
                Correct. 3400 top end is the limit for a stock 3100/3.1/2.8. Going .060 over might fix the problem and using 3400 gaskets. Im not entirely sure on that though.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Find out!
                    Pic of a 3500 head with a 05 3400 gasket...
                    • MY91GT(Z)
                      • Sep 2006
                      • 387
                      good pix and for those that want to know whats best to use on their swaps and y they r the better methods so that u dont have to do a build twice
                        Well rule of thumb is to always use a head gasket that pertains to your bore, so your sealing ring fits the cylinder, if you go larger you could run into some issues, and obviously if you go too small for the cylinder head you could also run into some major issues.
                        • Will'sFiero
                          Too many valves
                          • 276
                          So what are the actual fire ring diameters of the 3100, 3400 & 3500 gaskets?
                          Current:
                          \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
                          \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
                          \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
                          Gone, mostly forgotten:
                          \'90 Pontiac 6000 SE AWD: slow but invisible
                          • Scott_68B
                            • Nov 2003
                            • 147
                            Bringing this back from the dead out of curiousity, what issues would you run into if you used a 3400 head gasket on a 3.1/3100 block w/3500 heads?
                              Live life 3.7mi at a time
                              • 4555
                              The chamber will still overlap the deck.
                              EDIT: It also appears the valves would be shrouded by the cyl wall.
