The supercharger is done!!!
  • Dave96z34
    • Apr 2005
    • 624
    I took 10+ hours to fix but its runing. I found the crank pulley spacer was 1/8 of an inch short. It kept spiting a rib out a side so I found the flat ideler was leting it walk to one side. I went to autozone and snuck behind the desk and started rifling threw the ones they had. I found a nice ribed one that just needed a washer to move it outwords. I even had the perfect one. So I switched the sides the belt gat tensioned from. played with spacing for an hour. Got it runing in perfect alignment. I was afraid that the sc pulley would hit as well as the sc casing and the throttle cables so I cut the hole biger and clean the edges. Now I need to find the ruber doot trim so that it does not cut anyones hand. When I took it home I data loged most of the major information. Tuning start tomorrow.
    Video http://video.google.com/videoplay?do...48689513383782
  • DEI37
    • Jan 2004
    • 516
    What's it look like from inside? You gonna stick a cowl over that to protect it from the elements?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Are you sure you have enough hood opening to allow for engine/trans mount movement? Looks kind of close. If a mount were to snap/give, you think it'll smack off that hood some?
      • Dave96z34
        • Apr 2005
        • 624
        I used sawzall a die grinder to cut some of the extra off and the nabors called the cops. The cop spent 15min drooling over the car. LOL video up top.
        • zeethreefour
          • Oct 2006
          • 15
          nice work man...listen imma gettin alot of slack for dumping money into my z34...iam lookin to supercharge it or turbo it..what would u suggest. what parts do u feel should be upgraded when slapping a sc on?...what did u do to the lq1 to get that bad boy on there?
          plz let me know
          looks amazing
          • Dave96z34
            • Apr 2005
            • 624
            I would go with a turbo or a centrifugal supercharger. The lq1s heads are vary tall and I could not get any lower. If were to do it over I would do the centrifugal supercharger.
            • Guest
              When can we see dyno numbers?
              • FieroWannaBe
                • Mar 2006
                • 78
                The neighbors called the cops becuase you were cutting your car? WTF? I do what I want...
                when is it a crime to cut your car with a sawzall?
                Something cool coming soon...
                96 LQ1!
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  I bet it was past 10pm at night when the cops were called. lol
                  • Dave96z34
                    • Apr 2005
                    • 624
                    7pm the limit for work is 8pm too. Cop loved the car!
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      7pm? That really really blows. I don't quit until I am tired or finished or if weather is terrible... Usually 11PM
                      • Guest
                        when you going to hit a dyno?
                        • Fiero Brick
                          • Feb 2006
                          • 71
                          That's so awesome, it looks great. I still say you should clean up and dress up the hood opening you cut out, then just leave the SC sticking up in the wind. It would be badass. Let 'em know the nastyness under the hood and feel fear.
                          87 Fiero GT
                          2.8 liter v6
                          • dohcfiend
                            King Chalupa
                            • Jan 2004
                            • 2351
                            go dave. u da man. you're almost there. get it tuned in and enjoy. i think u should have something made for your hood like that photoshop u showed me.
                            • Dave96z34
                              • Apr 2005
                              • 624
                              The prob is that a cowl wold make it even harder to drive. But is is kinda killing the aerodynamics but it is leting it vent more and it runing cooler.
