I am installing a 3.4L SFI engine from an automatic transmission equiped Firebird into a manual equiped Trooper. I'm concerned about the ECU - do I need to mail it off somewhere to get reprogrammed, is it something I can do myself, or something I don't need to worry about?
Engine swap, ECU from Auto to Manual
'71 Opel Kadett Wagon - 1.9L CIH w/ Weber DGV 32/36, in bitsTags: None
I still need the transmission functions deleted from my ECU. Any advice in this regard would be appreciated. What equipment do I need to edit the ECU myself? I know a place that will do it for $170, would anyone with the equipment here be willing to do it for less?'98 Volvo V90 - Ford 5.0 swap in progress
i dont think many people here know much about the isuzu ecm.
what are the numbers on it, and on the prom ?
helps if you give full info about it.
obd1 ?
i think if you can find the software for it you need to go in and see if there are any flags that look like...
manual vehicle option flag
then you jsut set it to true by making sure its ticked with a check, or true or whatever
or manual shift logic...
It's not an Isuzu ECU, the engine and ECU came from a 1994 Firebird.'98 Volvo V90 - Ford 5.0 swap in progress
Hmmm, good timing.
"Down for maintenance."'98 Volvo V90 - Ford 5.0 swap in progress
I have a 5-speed ECM ordered, but I might try that grounding trick too - as I have another engine I may want to use the auto-ECM on.'98 Volvo V90 - Ford 5.0 swap in progress
I never did finish the project. It's a long story... I'm back to working on it again though. I ended up buying an ECU from a manual transmission equipped vehicle, and I was just going to strip the extra wiring from the harness.'98 Volvo V90 - Ford 5.0 swap in progress
