2.8L (Gen II) Specifications
    • 9183
    2.8L (Gen II) Engine Specifications
    [table="head;width=100%;"]
    Application
    |{colsp=2}
    Dimensions
    |Metric|English
    {colsp=3}General Data
    Type|{colsp=2}60 degree V6
    Displacement|{colsp=2}2.8L
    RPO|{colsp=2}LB6
    Bore|89.0 mm|
    Stroke|76.0 mm|
    Deck Height|224 mm|
    Compression Ratio|{colsp=2}8.9:1
    Firing Order|{colsp=2}1-2-3-4-5-6
    Oil Pressure|69 kPa @500 RPM; 205-380 kPa @ 2000 RPM|(10 psi @ 500 RPM; 30-55 psi @ 2000R RPM)
    {colsp=3}Cylinder Bore
    Diameter|88.983-89.017 m|
    Out of Round - Maximum|0.013 mm|
    Taper - Thrust Side Maximum|0.013 mm|
    {colsp=3}Piston
    Clearance|0.023-0.056 mm
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.051.089
    Second
    0.051.089
    Gap
    Top
    0.25-0.50
    Second
    0.25-0.50
    OIL
    Groove Clearance
    0.199 (Maximum)
    Gap
    0.25-076
    Piston Pin:
    Diameter
    22.992-22.997
    Clearance
    0.0064-0.0091
    Fit in Rod
    Press
    Crankshaft:
    Main
    Journal
    Diameter 67.241-67.267
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing Clearance
    0.030-0.069
    Crankshaft End Play
    0.05-0.20
    Crankpin
    Diameter
    50.757-50.785
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing Clearance
    0.036-0.091
    Rod Side Clearance
    0.36-0.68
    Camshaft:
    Lift
    Intake
    6.67
    Exhaust
    6.93
    Journal Diameter
    47.442-47.790
    Journal Clearance
    0.02-0.10
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle (Intake & Exhaust)
    45 degrease
    Seat Angle (Intake & Exhaust)
    46 degrease
    Seat Runout (Intake & Exhaust)
    0.02
    Seat Width
    Intake
    1.55-1.85
    Exhaust
    1.70-2.01
    Stem Clearance
    0.025-0.069
    Valve Spring
    Free Length
    48.51
    Pressure
    Kg @ mm
    Closed
    40.8 @ 43.2
    Open
    97 @ 32.79
    Installed Height
    40.01
    Valve Spring
    Damper
    Free Length
    48.51
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Camshaft Sprocket Bolts
    24
    18
    Connecting Rod Bolt Nuts
    51
    37
    Crankshaft Damper Bolt
    77
    104
    Cylinder Head Bolt (apply thread sealant to bolts)
    First Pass 45
    33
    Final Pass Add 90 Degrees
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    Exhaust Manifold Bolt
    24
    18
    Flywheel Bolt
    71
    52
    Front Timing Cover Case Bolt
    8mm 18-35 13-25
    10mm 27-47 20-35
    Lower Intake Manifold Bolt
    First Pass 22 16
    Final Pass 31 23
    Upper Intake Manifold Bolt
    22
    16
    Main Bearing Cap 99 73
    Oil Pan Bolt
    6mm
    8-12
    6-9
    8mm 19-30 14-22
    Oil Pump Bolt
    41
    30
    Rocker Arm Nut
    24
    18
    Timing Chain Damper Bolt
    20
    15
