Gear Ratios
    • 9185
    Gear Ratios
    Quad 4 Getrag
    89
    1st...3.50
    2nd...2.19
    3rd...1.38
    4th...1.03
    5th...0.72
    FDR...3.61
    1990
    1st 3.50
    2nd 2.19
    3rd 1.38
    4th 1.03
    5th 0.81
    Axle 3.61
    1991
    1st 3.77
    2nd 2.19
    3rd 1.38
    4th 1.03
    5th 0.81
    Axle 3.61
    1992-1994
    1st 3.50
    2nd 2.05
    3rd 1.38
    4th 1.03
    5th 0.72
    Axle 3.94
    1991-1993 W41
    1st 3.50
    2nd 2.05
    3rd 1.38
    4th 1.03
    5th 0.81
    Axle 3.94
    Isuzu L-Body
    1st 3.73
    2nd 2.15
    3rd 1.33
    4th 0.92
    5th 0.74
    Axle 3.83
    V6 Getrag
    All years J,L and W body
    1st 3.50
    2nd 2.05
    3rd 1.38
    4th 0.94
    5th 0.72
    Axle 3.61
    Sunbird/Grand Am 2.0l turbo
    1st- 3.50
    2nd- 2.19
    3rd- 1.38
    4th- 0.94
    5th- 0.72
    fdr- 3.61
  • rickykline
    • Oct 2006
    • 345
    can you put 91 quad 4 1st 2nd and 4th with a 92 3.94 fdr into say a v6 getrag or would that require alot of input and out gear changes?
    • rickykline
      • Oct 2006
      • 345
      what would it take to swap gears from the quad 4 to the v6 getrag... like take out a first and second and fourth from a 91 quad and put them into a v6 getrag??
      • pontiacjeff
        • Jun 2004
        • 147
        Updated info on the Getrag gear ratios:
        W-body V-6 used the same gear ratios as any other V-6 cars. The myth about the 3.77/2.19 gearbox comes from the W-body Quad 4 cars. They were the only W-body cars that had the 3.77/2.19, as did other Quad 4 cars of the same years. I have comfirmed this with a '89 2.8L Grand Prix, original transmission with partial vin stamped. Upon disassembly, the following gear ratios were noted:
        3.50/2.05/1.38/.94/.72/3.61
        Jeff Ianitello
        Engineered Performance
        Atlanta, GA.
          • 13505
          Thanks, that makes more sense Updated the top post.
          • GutlessSupreme
            • Nov 2004
            • 166
            I can confirm pontiacjeff's V6 W-body info.
            Application: '89 Cutlass Supreme International, 2.8 V6 5-speed, RPO: MG2
            Input shaft
            Input splines: 14
            1st drive gear: 14
            2nd drive gear: 20
            3rd drive gear: 24
            4th drive gear: 35
            5th drive gear: 43
            Output shaft
            FDR drive gear: 18
            1st driven gear: 49
            2nd driven gear: 41
            3rd driven gear: 33
            4th driven gear: 33
            5th driven gear: 31
            Reverse gear: 41
            Carrier
            FDR driven gear: 65
            VSS ring: 34 - hall effect electronic VSS
            Notes: old style (pre-'91) - cast finish, smaller spiders
            Reverse Idler Shaft
            Reverse idler gear: 29
            Other notes for all W cases: External slave/internal arm & fork, W-body specific case (W subframe mounting provisions), intermediate shaft
            The following numbers are from a 1987 "Muncie Getrag" 282 service guide from GM. I think Rodney Dickman had it hosted.
            1st: 3.50:1 - drive: 14, driven: 49
            2nd: 2.05:1 - drive: 20, driven: 41
            3rd: 1.38:1 - drive: 24, driven: 33
            4th: 0.94:1 - drive: 35, driven: 33
            5th: 0.72:1 - drive: 43, driven: 31
            R: 3.41:1 - drive: 12
            FDR: 3.61:1
            W-body V6 5TM40: 3.50/2.05/1.38/0.94/0.72/3.61
            -Tony | gtsdurango.net
            '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
            '90 Turbo Grand Prix STE - ehh.. I'm working on it.
            '92 Gutless Supreme SL - RIP 5.2010
            '90 Turbo Grand Prix - RIP 6.15.2005
