Camshafts
    • Jul 2026
    Camshafts
    Stock cam specs:
    Type : Hydraulic roller, assembled (hollow core with pressed on lobes)
    Duration : 196º intake / 196º exhaust (@ 0.050" lift)
    Lift @lobe : 0.273"
    with 1.6 roller rockers : 0.437"
    Lobe Seperation Angle : 112º
    Changes made between years:
    1994-1999 : cam sync ring was a "missing tooth" design, requiring cam position sensor AC Delco PN 213-294
    2000-2002 : cam sync ring was a "single tooth" design, requiring cam position sensor AC Delco PN 213-937
    2003-present : cam sync ring is a 50/50 pattern of raised and lowered semi circles, requiring cam position sensor AC Delco PN 213-1533
    • 13520
    Here are the stock cam specs from napaonline (changed the lift for our stock 1.6:1 rockers)
    Cam Lift (Exhaust):.272"
    Cam Lift (Intake):.272"
    Cam Timing at .050" Lobe Lift (Exhaust Close):12 Deg BTC
    Cam Timing at .050" Lobe Lift (Exhaust Open):32 Deg ABC
    Cam Timing at .050" Lobe Lift (Intake Close):29 Deg BBC
    Cam Timing at .050" Lobe Lift (Intake Open):15 Deg ATC
    Degrees Overlap:39 Deg
    Duration at .050" Lobe Lift (Exhaust):197 Deg
    Duration at .050" Lobe Lift (Intake):197 Deg
    Lobe Centerline (Exhaust):111 Deg
    Lobe Centerline (Intake):113 Deg
    Valve Lash (Exhaust):Hyd.
    Valve Lash (Intake):Hyd.
    Valve Lift (Exhaust):.430"
    Valve Lift (Intake):.430"
