questions,problems,eveything is never ending
  • Syn
    The Master Piece
    • Oct 2005
    • 599
    well for those who don't know of my car see the sig
    i am haven probs still. i can't get freescan to work and for tunerpro i need a definition file and can't find one for my car
    when i start my car it barley idles and sounds like a machine gun almost when i rev it.
    i need a datalog for sure
    is early obd2 knock sensors useless for me? i have one and a pig tail curious if i could use that.
    my first datalog a guy about a hr away came out for me but is too busy to do it again. i was getting max retard all the time and i changed the knock sensor and pig tail and it seemed to fix it for a day now i am back to it barley running,no power
    just makes me pissed spend like 2k+ on a pos v6 cavaler
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    sounds like how my carwas running, its getting better though
    sounds like it may be exteremly rich
    i was fairly un-impressed when i swapped my motor over to my gp
    man did it run like crap, but its gettign better
    lets start with freescan
    have you tried GM410B setting ?
    what aldl device do you have?
    what ecm do you use? codemask ect.. ?
    • Syn
      The Master Piece
      • Oct 2005
      • 599
      yeah its running rixh i am sure i pulled the plugs and they are black so its gotta be rich
      freescans set at gm410b yes
      aldl cable is from mastach.com its a serial aldl and i only know people with usb so i got a serial to usb adapter
      installed the drivers for the adapter and still nothing
      ecm whatever is in the stock 93 j bodys with the 3.1's lol
      codemask?
      i am new to tuneing as i am sure you can tell
      pic of cvable with adapter
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        ok thats what i use (mastach) where are you plugging the red and black wires into the aldl port ?
        here use this to test your mastach device
        FileFactory is the best place to upload and share files with no limits since 2005. Send and receive any type of file up to a massive 5GB with unlimited file bandwidth.
        let us know if you get any errors
        should be instructions if not make sure non of the wires are touching eachotehr
          the USB adapter looks to be the problem... they never seem to work right in this application. I bought the expencive one from radioshack and it works for everything else... lol
          you need the KS from the 3.1, even if it currently makes the car run like crap. See if you can find a laptop with a real serial port. Or if you can somehow bring it to the V6 bash i'll datalog it for ya
          I attached the $A1 .xdf file for tunerpro...
          • Syn
            The Master Piece
            • Oct 2005
            • 599
            sil i know it works because the guy who came out used it but he had a serial laptop but told me that the usb adapter will work
            aslo when i click ur link i get no downloadable link so i downloaded datamaster aldl interface tester
            but everytime i try and run freescan on my g/f's laptop and open freescan with the cable all connected i get,iirc can not find specified file. its been atleast a month since i've messed with my car and over 6mons since its been running and nothing has worked so i just let it sit cause this crap is retarted
            the ks is for a 3.1 i just had a obd2 ks chillin here. i wish i could of taken it to the bash i can't even start it let alone drive it.
            i put a gal of gas in it last week and its already all gone today after starting it for maybe 5 mins at a time 3 or 4 times in the last week
            something doesn't make sense there
            as for the xdf i downoaded it opened tuner pro hit select xdf clicke don the extracted file from winzip and it says invalid xdf file
            idk wtf is wrong
            incase noone saw it heres my first datalog from over a month ago i was running for 19lb injectors at the time, thought i was running too rich cause i was getting cylinder washing and now with the 3100's i'm getting the same thing. i believe its because the car isn't running right now. because my old 2.2 ran like crap because of the cps sounded almost like my car and i got cylinderwashing
            anyways heres the 1st datalog and only one
            • grandprixgtp_91
              • Nov 2003
              • 758
              i can tell you right now that a obd2 knock sensor will not work, it will cause max knock retard, i know from personal experience, something about there being an inline resistor , same with the connector, no good, you have to use both from the year of your car. start from there, i know how crappy a car runs with max retard , its pretty bad, i just disabled the whole knock retard settings on my chip to get rid of it.
              Jake
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                i know you have to scroll down a bit, the link is kinda hiden, but if you look it says download here for free
                please, download, if it doesnt work ill send it via email to you if you want
                i would really like to see if the usb adapter is causing your troubles
                just going 1 step at a time, trying to eliminate some variables here to pin point what might be wrong
                ill check your log and see if i can make sense of it, im still learning how to read them and spot things but i have an idea lol
                so ill post back tomorrow
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  wow i feel liek a dumbshit it was right there this time
                  but it was the same one i downloaded earlier thx tho just a some what diff name in the file download but same exact program
                  i wanna clear this up i am not using a obd2 ks i just had one sitting here
                  so you can get rid of knock retard settings when i go about burning the eprom?
                  interesting
                  if its the usb adapter i'm gonna be pissed and scred cause it was 30 bucks and i know absolutely noone with a serial port laptop
                  and don't have much money to spend or id throw down on one, just paid like 2k for college
                  i'm gonna see if i can get a datalog/test tomorrow before class
                  • scott0999
                    • Aug 2006
                    • 180
                    he needs the .ads file to datalog with. ive been looking all over trying to find this as well. unfortunately I think if hes having trouble logging with freescan that tunerpro wont work any better. I have a moates.net USB-ALDL cable and its worked in freescan and tunerpro
                    '94 Cavalier Z24 3400 Turbo 5 spd
                    • sil
                      4T60-E killa
                      • Nov 2004
                      • 723
                      syn, howd the tests go?
                      you have a laptop for datalogging, and a desktop as well?
                      i was gonna get you to run the tests without the usb adaptor on your desktop
                      then run with the usb adaptor on your desktop
                      then run the program on your laptop with usb adaptor
                      that way you can see wether it is your laptop, or the usb adaptor
                      cause obviously if it works with and without adaptor on your desktop then its your laptop
                      and if it doesnt work with usb adaptor on desktop then its the usb adaptor
                      • Syn
                        The Master Piece
                        • Oct 2005
                        • 599
                        i have a desktop but i borrow a friends or usually my g/f's laptop to try and datalog
                        but i get what your saying process of elimination
                        pulling my desktop out side to datalog lol?
                        • sil
                          4T60-E killa
                          • Nov 2004
                          • 723
                          no need to pull the puter outside to test the aldl cable
                          just hook it up to your desktop and run the program
                          make sure the wires arent touching eachother when you do
                          lol, well if its the usb adaptor and you cant get it to work....
                          (i may be able to help, just gotta make sure its that)
                          ....and you cant borrow a laptop with serial, then you might have to bring the desktop out to the car to tune lmao
                          ya thats what i do becuase im stuck with no laptop lol
                          its a PIA, but it works
                          but lets go 1 step at a time hehe see if its the laptop or the usb adapter :P
                          • grandprixgtp_91
                            • Nov 2003
                            • 758
                            I have a serial port laptop if you need, i know your close to me, i can probably help you work some stuff out if you need some help.
                            Jake
                            • Syn
                              The Master Piece
                              • Oct 2005
                              • 599
                              ok just did the testing, the usb serial adapter connected to the aldl cable ran the test it passed!
                              ran it without and it passed, so some how some way the laptop i am using is a high ass pos
                              BUT
                              i did take my desktop to my car one time to try and run freescan and i ran into the problem i'm haven so that doesn't make sense.....
