Thermostat
    • 9187
    Thermostat
    I'm going to keep this short, because its a simple concept. For years people have been spreading the word that a 160 stat will cause problems. This is true, as it hurts gas milage and MAY cause the cylinder walls to wear faster due to less expansion. If your fan turn on times aren't matched, it can allow a cycle of 160 to 220 degrees back and forth, which will contract and expand the cylinders.
    However, there is a myth in here as well. Open loop operation does not care if you have a 160, 180, or 195 degree stat. Closed loop is based on exhaust temp (O2 sensor working properly), coolant isn't below freezing (i have to look up the exact temp again...its really low though), and the time the car has been running.
  • Andromeda451
    • Mar 2007
    • 14
    Thermostat
    When an engine runs cool due to a low temperature thermostat being installed doesn't the computer compensate for a cooler engine by running a slightly richer mixture to aid driveability ?
    Andromeda451
    Phx, AZ
    99 Lumina LS
    92 Jetta GLi16V
    78 Porsche 924
      • 13520
      Id have to look through the tables again but I know in open loop, it runs much richer on cold starts. It would make sense for there to be added fuel from being colder but im not sure how much. It could be the reason I lost 1-2 mgp with a 160 years ago.
      • Alero99
        • Apr 2007
        • 1
        Would a 180 thermostat hurt my engine?
