properly testing ignition coils ?
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    i was looking through my crappy haynes manual and i didnt see anything about coil resistances or how to check them also googled and didnt find anything about the resistances or hwo to check them
    can anyone explain the process?
    and does anyone know the proper resistances @ 0 and 70 Deg F temperature ?
    Thanks
    edit* guess the coil packs are the same for most gm models and apps ?
  • montess408
    • May 2006
    • 391
    set the ohmmeter on the rx1 setting
    place one lead on each primary terminal primary resistance should be less than 10 ohms
    set the ohmmeter on the rx1000 scale
    connect one lead to any primary terminal and the other lead in or on the coilsecondary tower secondary resistance should be between 5,000and 25,000ohms
    if the coil fails this test ,replace it
    • torq455
      If I only had money!!!
      • Dec 2003
      • 1615
      i thought resistance between the tower coils was supposed to be between 5-7K ohms.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • gserlenga
        • Aug 2006
        • 13
        yeah, mine read 5700 ohms at the secondaries when i checked them, i think 5-10k is within spec
        • prophiseer
          Blaspheming Heretic
          • Jun 2006
          • 354
          Seeing as how this post was lost, I'll throw this link back up: (.pdf format)
          Tech Tip
          N-body enthusiast:
          {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
          {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
          Current Project:
          {'90 Chevrolet C1500 Sport 350TBI}
          • sil
            4T60-E killa
            • Nov 2004
            • 723
            OMG thanks
            athough i did manage to figure out my problem, 1 tower #4 wasnt sparking
            thanks for the reply, that was gold *right click save as* lol
            • prophiseer
              Blaspheming Heretic
              • Jun 2006
              • 354
              no prob that's saved me from many a frustrating diagnosis in the shop
              N-body enthusiast:
              Current Project:
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                let me get this strait.........
                primary(paperclip stuck in bottom plug) to tower(Secondary) should read 5000-7000 ohms?
                or is it tower-to-tower 5000-7000 ohms?
                reason i ask is because im not getting anything, on primary-to-secondary tower test, on all 3 of my coils.....
