Pushrod Length
  • 89CieraSL
    • May 2005
    • 1
    Pushrod Length
    Does anyone know on the Gen II motors which pushrods are the longer ones? Intake or Exhaust? I just installed my new cam, rockers and pushrods and the rocker nuts keep backing off. This is the 7th time its happened. Im thinking I have a pushrod mixed up but dont remember which is longer. Thanks
    1989 Cutlass Ciera SL Coupe
    2.8 Multi-Port Engine
    Cold Air Intake
    Flowmaster Exhaust
    MSD Coils
    FastFWD Performance U/D Pulley
    Custom JET Chip
    Comp Cams 1.52 Roller Rockers
    Comp 212/212 .440 Lift Cam
    New Comp Springs
  • GinoBeats
    • Mar 2005
    • 145
    The exhaust are the longer ones
    http://www.v6z24.com/registry/ginobeats/
    http://www.v6z24.com/registry/ginobeats/2
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Get new nuts. It is a common problem with the prevailing torque nuts (Also known as Stover nuts) once they are used they *should* be replaced. Often you can get away with out replacing them. But in this case it looks like you can't.
      • Blackrider
        • 131
        I'm Farly Certen that the Gen II's are the same as the Gen III's, where as an exhaust pushrod mixed up with an intake pushrod will result in a bent intake valve.
        The exhaust pushrods are 6 inches and the Intake are 5.75 if i'm not Mistaken.
        The order is as fallows, Exhaust ports towards you E I I E I E.
        2006 G6 GTP MT6
        Vector Motorsports ECU
        Classic Performance 2.5 Inch Exhaust
        v6h.o. Downpipe
        Custom Intake
