3.4 destroked
  • 1971mgb
    • Mar 2006
    • 6
    3.4 destroked
    Found some info please correct me if not. An iron head flows 183 cfm approx at .50 lift so computing those numbers you come out with 282 theoretical h.p. . At a twin turbo v/e of 1.25 comes out to 352 h.p. on boost from stock heads. 385h.p. and 367 ft.lb tq. on heads that flow 200cfm.So anyone know the flow of their heads?And will a simple port match and blend flow the extra 10%? how does 10.80s @127mph sound!With 180 flow heads should pull strong to 6000 rpm.At 200cfm heads 6500rpm.Yikes I've created a monster.
    6.23 h.p per lb. thats a full 3lb per h.p. lower than one of those butt ugly lotus's and they are good for 4.3s 0-60 ,and lower than a new small block 427 vette.So please dig up those head flow numbers so I can finish this engine and get onto the suspension.
    Thanks again,
    Rob
