.001" oversized main bearings?
  • Doward
    • Dec 2003
    • 127
    I know they have 'em for the SBC, but what about us 60º V6 guys? I'm sitting @ .003" main bearing clearance across the board, and would like something a little better, without cutting the crank
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
  • Naft
    • Jan 2006
    • 19
    I saw a set somewhere . . . absolutely no clue where, i wasnt looking for them so i dont remember. just confirmation that they are out there if you want to bother scouring the internet!
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      You want more clearance?
      You are already over the max. Max is 0.0027"
        • 13499
        I thought oversize were smaller to make up for the crank journals being cut down.
        • treeZ24
          i wanna go fast!
          • Mar 2004
          • 251
          i believe he meant to say undersized bearings, taking up the slack for the lil bit of wear on the crank..
          got zap-straps?
          89 Z24
          13.886 @ 96.16 mph
          street trim - slicks
          • tejohnson
            • 359
            Clevite has .25mm, .50mm, .75mm, an 1mm undersize bearings with a part number of: MS2037P
            Does that help?
            Regards,
            Todd E. Johnson
            • Doward
              • Dec 2003
              • 127
              You guys are right, undersized bearings! I think of them as 'oversized' because the bearing is .001" thicker than stock
              Main Bearing Clearance for an LH0 motor is 0.0012 - 0.0030", so I'm on the outer limit right now. That's why I'm looking for some .001" bearings. That would be like a .025mm bearing
              Currently using standard sized MS2073P Clevites.
              222/291 @ wheels
              T61 on the way!
              • Doward
                • Dec 2003
                • 127
                OMFG - THEY MAKE .001" UNDERSIZED BEARINGS FOR A BUICK 3.0L?! I've never even HEARD of this motor - yet they have undersized bearings? I'm going to keep looking...
                222/291 @ wheels
                T61 on the way!
                • Naft
                  • Jan 2006
                  • 19
                  i think its like an uber-destroked 3.8, or smaller bores.
                  btw it may have been .003 bearings i saw, but im pretty sure it was .001
