FS: ported 3500 plenum, TCE adapter, 62mm TB
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    Due to a failed project, I have some extra parts to get rid of (buyer pays shipping charges if applicable):
    1. Ported 3500 plenum. Bought from Ben through the store a few months ago. Tried bolting it up to the car, but won't clear the 3400 FPR/fuel rail when used with TCE phenolic spacers. Painted black; but otherwise new (car never ran with it). Store lists them at $190; I'd like $140.
    And, if the buyer so desires, I'll add a brand-new 3500 MAP sensor, wiring harness, and hold-down bracket for no additional charge. ***SALE PENDING***
    2. TCE billet TB adapter plate, for bolting their TB to a 3500 plenum. Again, brand new. $30 OBO. ***THIS ITEM SOLD***
    3. Billet 62mm throttle body. This is one of the original pieces that Kimmo made and Franz sold through FDP. Includes butterfly and linkage for 2000 Alero and others (the "A" style linkage as listed in the 660 store). Used but perfectly functional and in good cosmetic condition. $100 OBO. ***THIS ITEM SOLD***
    Pics are available for serious inquires. Paypal accepted (I can take credit cards), but buyer must pay any additional Paypal fees. Thanks for looking.
    Matt
    • 13467
    The FPR adapter should let it clear with the spacers.
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      I have the FPR bracket also, and it won't fit.
      Matt
      • black05gt
        Damn Yankee
        • 74
        3500 plenum with 3400 FPR and fuel rails
        That's the setup I've got on my '05 GAGT - where are you getting clearance issues ? And I'm also using parts supplied by Ben (the plenum, the adapter, a 65mm TCE TB, and the fpr bracket). Just curious to see if there's some engine difference that's caused this apparent problem,
        ported 3500 heads, LIM, plenum, 28# TB FI's, TCE 65 mm TB, MPR CAI, F&R strut bars, F&R sway bars, Eibach springs, KYB GR2's, TOG headers, hi-flow cat, Borla muffler and tips, LC-1 WBO2, DHP PT
        • mfuller
          Mr. Common Sense
          • Nov 2003
          • 374
          It'd fit except I have the TCE phenolic plenum spacers. The spacers raise the plenum 1/2". so the wide "ring" around the FPR interferes with the plenum. No amount of tweaking to the fuel return line would make it work.
          Matt
          • black05gt
            Damn Yankee
            • 74
            Hmm , I have the same spacers, I'll have to look closer - I wonder if there is some subtle difference in the plenum shape or height . Anyway, good luck with the sale...
            • ghostgt
              • Jan 2006
              • 19
              Hey,can i get a pic of the TB and what would i need to do to it for it to fit my 98' 3100? Trav
              ditchbangin500xc@hotmail.com
              • mfuller
                Mr. Common Sense
                • Nov 2003
                • 374
                E-mail sent.
                Matt
                  where the bolt goes through the FPR, cut out the top of that hole and put a washer on the bolt. that let me turn mine to clear the 3500 plenum. If you have Ben's bracket that may just give you the extra clearance you need.
                  • Guest
                    Interested in the TB. Please send pics to Shaun41178@hotmail.com I dont' have the ability to check my pms's
                    THanks
                      • 13467
                      Ok, I rechecked and your FPR should clear. You will have to bend the line a little, but there is no reason that when you screw the FPR into that adapter, using the spacers, that it won't clear the plenum. Its close, real close but it clears. You will have to set it on and slide it forward to clear it on install, but that is it.
                      http://60degreev6.com/sappyse107/3500TESFPRsetup
                      There are the pictures I took.
                      • mfuller
                        Mr. Common Sense
                        • Nov 2003
                        • 374
                        I'll try it again sometime this week, but tweaked the return line pretty good (I was afraid of cracking it) and it wasn't close. We'll see.
                        Matt
                        • mfuller
                          Mr. Common Sense
                          • Nov 2003
                          • 374
                          Sale is pending for the 3500 plenum.
                          Matt
