Valvetrain Information
    • 9187
    We have been getting several questions lately on the forums concerning parts associated with the valvetrain. I decided to start a general information article covering common questions that come up. Hopefully the article will grow to a wealth of information.
    Use the Table of Contents on the right to go to the appropriate section.
    [break=Pushrods]Pushrods
    Pushrod Length
    Intake pushrods measure 144.18 mm (5.68 inches) long.
    Exhaust pushrods measure 152.51 mm (6.0 inches) long.
    Pushrod Locations
    [center][table="width=200]{colsp=4}[b][size=3]Firewall[/size][/b]
    CYL|Valve|Valve|CYL
    [size=4][b]5[/b][/size]|Exhaust Intake|Exhaust Intake|[size=4][b]6[/b][/size]
    [size=4][b]3[/b][/size]|Intake Exhaust|Exhaust Intake|[size=4][b]4[/b][/size]
    [size=4][b]1[/b][/size]|Intake Exhaust|Intake Exhaust|[size=4][b]2[/b][/size]
    {colsp=4}[b][size=3]Radiator[/size][/b]
    [/table][/center]
    [break=Rocker Arms]
    [color="orange"]Under Construction...[/color]
  • ckrobins
    • Jun 2006
    • 18
    Is the pushrod location drawing for a RWD car? I have a transverse-mounted engine (generation II - VIN M) and "Radiator" and "Firewall" would belong on the right and left of the diagram, respectively. The engine block/timing case and the fuel injector wiring harness are set up this way, but the intake manifold has cylinder numbers cast into it showing the even cylinders (2-4-6) on the firewall, and the odd cylinders (1-3-5) on the radiator side. Are there other 60degreeV6 engines that have this cylinder arrangement? I suspect that the intake manifold may have been replaced with one from a different engine model.
    Experience is an expensive teacher, but fools learn from no other. Mark Twain
